Strange H4 on 18F6722
PostPosted: Fri Feb 03, 2006 8:22 pm     Reply with quote
I have a code that run in a 18F6722 with 10Mhz H4 = 40000000Mhz the code have strange funcionality, but in 10Mhz HS the code work OK.
Somebody have some experiencie in use H4?
The compiler have any bug in H4?
I wait for your comments,
asmallri
PostPosted: Fri Feb 03, 2006 8:54 pm     Reply with quote
The PLL is enabled by the fues setting at power on reset. Did you power cycle the PIC after setting the fuse for the first time?
Regards, Andrew
PostPosted: Fri Feb 03, 2006 9:48 pm     Reply with quote
Dear asmallri,
I not understand the power cycle, can you explain best.
Thank you very much!!
asmallri
PostPosted: Fri Feb 03, 2006 11:02 pm     Reply with quote
Turn power off. Wait 5 seconds. Turn power on.
Regards, Andrew
tophe59
PostPosted: Sat Feb 04, 2006 12:06 am     Reply with quote
The H4 break debug for me. I using internal RC*4 Crying or Very sad
cfernandez
PostPosted: Sat Feb 04, 2006 6:47 am     Reply with quote
How to use Internal RC*4 ????????????
tophe59
PostPosted: Sat Feb 04, 2006 1:38 pm     Reply with quote
i configure in RC mode with #fuses and enable pll in the code.
specialk
PostPosted: Sat Feb 04, 2006 6:36 pm     Reply with quote
See section 2.4.2 of the 18F6722 datasheet.
