LCD Problems |
Posted: Sun Feb 12, 2006 9:36 pm |
I just graduated from school and I'm working on projects to help advance my knowledge while I'm looking for a job. Currently I'm working on connecting an LCD to a PIC16F874, but I'm not having much luck. I've learned enough about the connections - I'm positive my wiring is correct. But what I'm having trouble with is getting the software to work. My clock is a 20 mhz oscillator, which might be a problem, but other than that I can't understand why this isn't working. My code is below:
Code: | #include <16F874.H>
#include <stdlib.h>
#include <lcd.c>
main() {
lcd_init();
lcd_putc("\fDoes this work\n");
//printf(lcd_putc, "Hello World.");
I'm not exactly sure what the problem is, whenever I run this code the LCD just spits out like 5 or 6 characters (I'm not sure how many, I haven't counted them, but it's the same each time). But the characters themselves is basically a black box, only one dot is missing, so something like this:
see how one dot was gone?? I don't know what the problem is. Do I need to manually change the enable pin and make it go from high to low? I can't see how that would be the case because I'm using this function....please help...
-Chris |
Posted: Sun Feb 12, 2006 9:51 pm |
Download the Microchip PicDem2-Plus manual here:
http://ww1.microchip.com/downloads/en/devicedoc/51275b.pdf
Go to page 20, and look at the LCD schematic in the upper left corner.
How is your circuit different from this one ?
Note that though they show trimpot R20, on the actual board it is not
installed. Only R5 and R6 are installed. |
Posted: Sun Feb 12, 2006 10:18 pm |
According to the LCD.c file, these are what my pins are connected to:
Code: | // As defined in the following structure the pin connection is as follows:
// B0 enable
// B1 rs
// B2 rw
// B4 D4
// B5 D5
// B6 D6
// B7 D7
// LCD pins D0-D3 are not used and PIC B3 is not used. |
Also, although you can use two resisters to do the job, I'm actually using a 10kohm POT. Not that it matters, both ways work.
Let me know if you have any other advice. |
Posted: Sun Feb 12, 2006 10:32 pm |
Strip your program down to essentials. Also, you didn't post a
#fuses statement. I have added one.
Try this program:
#include <16F874.H>
#include <lcd.c>
lcd_init();
printf(lcd_putc, "Hello World");
