DAC PROBLEM on 16f877
jruibarroso
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Thu Feb 02, 2006 2:19 pm     Reply with quote
Is possible to use analogs ports to output 0 ..5 v on a PIC 16F877 ?
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Thu Feb 02, 2006 2:34 pm     Reply with quote
No. The analog ports on 16F877 (and I think on the rest of the PICs to) are either analog inputs or digital I/O. However, aside from buying a separate DAC chip, you can build a cruide DAC out of a PWM output, a low-pass filter and feedback to the PIC's A/D. This technique has been discussed in this forum:
http://www.ccsinfo.com/forum/viewtopic.php?t=19899
http://centauri.ezy.net.au/~fastvid/picsound.htm
Eugeneo
PostPosted: Fri Feb 03, 2006 12:40 am     Reply with quote
Take a look at the Mchip TC1321
I used this quite a while ago but it worked great.
It's a 8 pin soic with a 12 bit res.
No opamp/fet required.
SPI
And you can set it up in about 1 hour
http://www.microchip.com/ParamChartSearch/chart.aspx?branchID=11028&mid=11&lang=en&pageId=79
