18f6525 timer3 interrupt problem
jg
PostPosted: Wed Feb 01, 2006 2:31 pm     Reply with quote
Using PCH v 3.230.
Code below.
Explanation: Timer 2 provides the period (1Khz)for the software PWM. I need two seperate duty cycles. Timer 4 provides one and timer 3 provides the other one. Timer 4 is adjustable (30-99% of 1Khz) depending on a setting, this part works flawlessly. My problem is with timer 3, I'm wanting a fixed 50% duty cylce of the 1Khz. Using the o-scope on a pin it works "most of the time", but a lot of the time it is a 2% duty cylce instead of the set 50%.
I'm not using either compare or capture, what else could cause the timer1 to interrupt before it rolls over?
void timer2_int(void)
set_timer4(0);
PIR3 &= 0xF7; // clear interrupt for Timer
enable_interrupts(int_timer4);
if(PWM_dutyflag)
output_high(regulator);
output_low(regulator);
//PMW for dump valve
output_high(SOLSTART);
set_timer3(64900);
enable_interrupts(int_timer3);
#int_timer4
void timer4_int(void)
disable_interrupts(int_timer4);
#INT_TIMER3
void timer3_int(void)
disable_interrupts(int_timer3);
if(!(input(compsw)))
output_low(SOLSTART);
Thanks for the time.
PostPosted: Wed Feb 01, 2006 3:03 pm     Reply with quote
In your post you refer to Timers 2, 3, and 4, and you have code for
them, but then in your question you ask about Timer 1.
Can you explain this ?
jg
PostPosted: Wed Feb 01, 2006 3:18 pm     Reply with quote
timer1 was a typo, should read timer3
PostPosted: Wed Feb 01, 2006 4:10 pm     Reply with quote
I noticed two things:
1. You clear the interrupt flag for Timer4 before you enable it,
but you don't do this for Timer3.
2. You read a switch inside the Timer3 isr. Switches can bounce.
jg
PostPosted: Wed Feb 01, 2006 4:21 pm     Reply with quote
not a switch, but either way wouldn't cause what I am seeing.
I'll try clearing timer 3.
