Having a RS485 and RS232 port on a PIC18F1320
Maverick72
PostPosted: Wed Feb 01, 2006 3:03 pm     Reply with quote
I'm trying to setup two serial ports on my chip. I already use the PIC USART module, but can't seem to be able to use the
#use rs232(baud=9600,xmit=PIN_DALLAS_TX,rcv=PIN_DALLAS_RX,stream=DALLAS)
Command to implement my other port. Could you please help me.
P.S. Here's my serial interupt routine.
#int_RDA
void UART_RX(void)
int i=0;
int timer_usart_rx=0;
if (kbhit(RS_485))
/* Boucle pendant 20msec ou jusqu'à ce que le buffer soit plein */
while(timer_usart_rx <= MAX_USART_TIMER && i <= RS485_BUFFER_SIZE)
if(kbhit(RS_485))
rs_485_buffer[i]=getc(RS_485);
i++;
delay_ms(1);
timer_usart_rx++;
bit_set(flag1,RS_485_RX_FLAG);
PostPosted: Wed Feb 01, 2006 3:36 pm     Reply with quote
Show both of your #use rs232() statements, and show the #define
statements for all constants that you use in them. (Like the "DALLAS"
constants above).
