rwyoung
Joined: 12 Nov 2003 Posts: 563 Location: Lawrence, KS USA
Posted: Thu Feb 02, 2006 5:10 pm |
I don't believe the PIC18F4620 and the PIC18F2331 are pin for pin compatible. If you already have a PCB made then the new part probably won't fit. The PIC18F2431 is the step up from the 2331 in memory. The PIC18F2525 might match up pin for pin but you definately need to check. _________________ Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month! |
rwyoung
Posted: Thu Feb 02, 2006 5:12 pm |
sonicdeejay wrote: | thx for the reply....
if i want y=3.24 ,, y has to be delcared as "float" or any other alternative to bring the space down....??
or addional RAM chip is a solution.....?? |
RAM capacity isn't your problem. ROM capacity is. See the above comments by several people. _________________ Rob Young
sonicdeejay
Posted: Thu Feb 02, 2006 7:59 pm |
rwyoung wrote: | I don't believe the PIC18F4620 and the PIC18F2331 are pin for pin compatible. If you already have a PCB made then the new part probably won't fit. The PIC18F2431 is the step up from the 2331 in memory. The PIC18F2525 might match up pin for pin but you definately need to check. |
yes they are not pin for pin compatible... I'm sti in breadboard connection stage ,,,so I can change the connection layout easily...
here is comparison of 2 chips... my new chip PIC18F2525 will be delivered tomorrow,...
