Flaky int_ext
mat72
Flaky int_ext
PostPosted: Sun Jan 22, 2006 8:54 pm     Reply with quote
I have the following simple program which performs an ADC on channel 0 and has an external interrupt on RB0/INT0
#include <18F4550.h>
#include <ctype.h>
#fuses HS,NOPROTECT,NOLVP, NOWDT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
unsigned value=0;
unsigned adc = 0;
/*************************Interrupt Functions*************************************/
#INT_EXT
void ext_isr(){
   value++;
delay_ms(10);
   //printf("PULSE\n\r");
void main()   {
   set_tris_b(0xFF);   // port b as input;
    enable_interrupts(INT_EXT);// turn on interrupts
   ext_int_edge(H_TO_L);      // init interrupt triggering for button press
   output_d(0xff);
   delay_ms(20);
   printf("Sampling:\n");
   while(true){
   adc = Read_ADC();
   printf("Value: %u    \r",value);
The ISR is not called unless I remove the ADC stuff
setup_port_a( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
What is causing this?
Thanks,
Matt
[/code]
PostPosted: Sun Jan 22, 2006 9:09 pm     Reply with quote
See my post in the middle of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=25631&highlight=interrupts+use+delay
kender
Re: Flaky int_ext
PostPosted: Sun Jan 22, 2006 10:02 pm     Reply with quote
#INT_EXT
void ext_isr(){
   value++;
delay_ms(10);
The delay in your ISR might cause you to loose the next external interrupt. Is the purpse of the delay to debounce the switch?
mat72-not logged in
PostPosted: Mon Jan 23, 2006 7:38 am     Reply with quote
The purpose is to debounce. The switch is a magnetic sensor from an exercise bike. Is there a hardware debounce solution for a single pole switch?
Also I still have the problem without the delay. Right now its the ADC stuff that affects it. If I remove all ADC code then the interrupt works fine.
Thanks,
Matt
treitmey
PostPosted: Mon Jan 23, 2006 9:23 am     Reply with quote
I use int_ext for my keypad like this
http://www.edn.com/contents/images/601828f1.pdf
The debounce is done with the 2.2uf
But I don't know how much "BOUNCE" the mag switch will have.
mat72
PostPosted: Tue Jan 24, 2006 5:35 pm     Reply with quote
I've replaced "setup_port_a( ALL_ANALOG );"
with "setup_adc_ports(AN0);"
This solved my problem. Why wouldn't "setup_port_a( ALL_ANALOG );" work?
Also I've removed the delay which didn't effect anything.
Thanks,
Matt
kender
hardware debouncers
PostPosted: Tue Jan 24, 2006 5:45 pm     Reply with quote
There is information about hardware debouncers in this threadhttp://www.ccsinfo.com/forum/viewtopic.php?t=24103
jds-pic
PostPosted: Wed Jan 25, 2006 1:29 pm     Reply with quote
the sledgehammer approach:
http://www.linear.com/pc/productDetail.do?navId=H0,C1,C1003,C1144,C1129,P10330
Cool
jds-pic
