Using spi_write() with SSP interrupts in Master mode
mpfj
PostPosted: Thu Jan 26, 2006 4:19 am     Reply with quote
I am using SPI Master mode on an 18F8722.
My code uses an interrupt routine to handle the *outgoing* transfers. To initiate the transfer, I use the code ...
/* Routine to send / receive io poll message */
void io_poll(void) {
   int8 i;
   // create transmit data in poll message
   io.buffer[REG_DIGOUT] = digio.digouts;
   io.buffer[REG_CARD_BITS] = cardreader.num_bits;
   // set # bytes to transfer
   io.buff_count = REG_MAX - 1;
   // init buffer index
   io.buff_index = 0;
   // send first byte (REG_VERSION)
   spi_write(0x00);
   // now just wait for the int_ssp irq ...
Howevert, looking at the listing file, the spi_write() command generates the following code ...
....................    // send first byte (REG_VERSION)
....................    spi_write(0x00);
0A476:  MOVF   FC9,W
0A478:  CLRF   FC9
0A47A:  BTFSS  FC7.0
0A47C:  BRA    A47A
As you can see, the SSP1BUF is read (to clear any pending received data), then the SSP1BUF is written with 0x00 (as required).
*But* then the code sits in a tight loop waiting for the BF (buffer full) bit to be set in the SSP1STAT register.
I don't want this tight loop to happen, since the hardware will generate an interrupt when the byte transfer is complete.
I know I can write my own code to do this, but why can't the compiler acknowledge the fact that I'm using the SSP interrupt, and hence only do the "write" portion of the code ?
PostPosted: Thu Jan 26, 2006 4:45 am     Reply with quote
Realistically, the easy answer is just to write your own functions. The I2C/SPI function in CCS, are not that well implemented for many uses (as you say, the SPI functions do not suit interrupt applications), and if they try to make the functions 'smarter', so they recognise the 'mode' you are working in, it'd be more likely to lead to problems. An 'optional' second variable, that allows wait to be enabled/disabled, would be the ideal solution. I'd suggest you ask them for this!. However in the meantime DIY is 'trivial'. I used:
#byte   SSPBUF = 0xFC9
#byte   SSPCON = 0xFC6
#byte   SSPSTAT = 0xFC7
#bit          SSP_DATA_IN = SSPSTAT.0
#DEFINE   READ_SSP()   (SSPBUF)
#DEFINE   WAIT_FOR_SSP()   while((SSP_DATA_IN)==0)
#DEFINE   WRITE_SSP(x)   SSPBUF=(x)
#DEFINE   CLEAR_WCOL()   SSPCON=SSPCON & 0x3F
These give byte read/wite, and code to wait for the data to arrive, or be sent, as required.
