dima2882
| Creating a programmable current load |
Posted: Tue Jan 24, 2006 9:15 am |
Hi all,
I'm trying to use the PIC in an application that tests a commercial DC-DC converter at diffrent loads. I wanted to avoid using load resistors and instead have the PIC use a digital trimmer, like the MCP42010, to control a FET circuit that pulls a specified current from the DC-DC and loads it down. I want the circuit to be sensetive to variations in its supply, so that a low voltage out of the DC-DC causes lower current loads. Does anyone know what that kind of circuit might look like? Any suggestions are appreciated.
-Dima |
ruediw Guest
| Re: Creating a programmable current load |
Posted: Tue Jan 24, 2006 10:17 am |
| dima2882 wrote: | Hi all,
-Dima |
I would create a voltage controled current source (sink).
And control this from a D/A-Converter attached to the PIC.
You may build this current source with little component count:
OP-Amp with a fiew resistors and a transistor. Type and cooling of the transistor depends on the voltage and current you want to test.
HTH
Ruediw |
dima2882
Posted: Tue Jan 24, 2006 10:34 am |
I'm actually looking to sink quite a few amps. The DC-DC needs to be walked over its range of 0-7A. I'm a bad analog guy :( If anyone has more details, I'd love to know!
Humberto
kender
Posted: Tue Jan 24, 2006 2:18 pm |
In the circuit shown below the op-amp with a feedback will drive the MOSFET in such a way that the voltage at the negative input will be the same as the on the positive input, which you are driving with a DAC. The voltage on the negative input is I*R1 - proportional to the current.
to the circuit you are loading
|\ U1 |
DAC or PWM+LPF | \ |
--------------------|+ \ ||-- Q1
| \----------------------|| MOSFET rated for 7A
---|- / --- C1 |
| | / --- 100pF |
\ R1
/ Current-sense resistor
\ should be able to dissipate I^2*R
/ 1%
___
/// GND
SherpaDoug
Posted: Tue Jan 24, 2006 3:41 pm |
| dima2882 wrote: | | I want the circuit to be sensetive to variations in its supply, so that a low voltage out of the DC-DC causes lower current loads. |
So you don't want just a current sink. You want something more like a simulated resistor. That is a little more complicated, but if you already have a uP the easiest way is probably to just measure the voltage and calculate the current it should draw. Then use the current sink others have described to draw the current you calculated. _________________ The search for better is endless. Instead simply find very good and get the job done. |
kender
Posted: Tue Jan 24, 2006 5:08 pm |
| SherpaDoug wrote: | | dima2882 wrote: | | I want the circuit to be sensetive to variations in its supply, so that a low voltage out of the DC-DC causes lower current loads. |
So you don't want just a current sink. You want something more like a simulated resistor. That is a little more complicated, but if you already have a uP the easiest way is probably to just measure the voltage and calculate the current it should draw. Then use the current sink others have described to draw the current you calculated. |
If you can sample the voltage fast enough, then Doug's method is the easiest.
If you are less tolerant to the delay, Humberto's circuit would work best.
To add digital control to it, you migh alternatively replace R1 and/or R2 with a digital POT. |
dima2882
Posted: Wed Jan 25, 2006 7:21 am |
| Yes, Doug's simulated resistor concept is exactly what I'm looking for. I will try to implement this in a 40 MHz PIC and external A/D, that should be fast enough. Thanks for all your help. |
