osccal for the 675
Eugeneo
osccal for the 675
PostPosted: Mon Jan 23, 2006 8:54 pm     Reply with quote
The Machx OSCCAL value is sometimes has a slightly different value than the factory value. I'm thinking my room temperature is about room temp and the Machx has a voltage regulator on it. My scope is not accurate enough to tell me which is right...
I know it's trivial. But which would you guys trust?
cmdrdan
PostPosted: Mon Jan 23, 2006 9:14 pm     Reply with quote
Your home setup versus millions of dollars of production test equipment? Maybe it is my test engineer's bias, but I'd go for the factory numbers Smile
Dan
PostPosted: Tue Jan 24, 2006 5:24 am     Reply with quote
Personally, why not test the results?.
The OSCCAL values from the factory, are sometimes not that accurate. They are generated in a similar way to that used by Mach-X, but using a computerised DFM, rather than just counting pulses in a time period. I'd doubt if the Mach-X values would differ by much (typically just a couple of counts in the last significant bits). However it is relatively simple to write a program, that operates an output pin, counts for a long time (perhaps 100seconds), and then changes the pin again. Done right, the time can be tested with a stopwatch, and would give a 'check' quite easily, to well better than one part in one thousand. You would then 'know' which was the better result.
