I2C whatever
PICLeo
View user's profile Send private message ICQ Number
I2C whatever
PostPosted: Mon Jan 23, 2006 4:12 am     Reply with quote
Hi
Since a few days I try to get two 18F242 connected. Here the code.
MASTER:
BYTE data;
#int_TIMER1
TIMER1_isr()
   output_high(PIN_B3);
   i2c_start();
   i2c_write(0xa0);
   i2c_write(0xEE);
   i2c_start();
   i2c_write(0xa1);
   data = i2c_read(0);
   i2c_stop();
   printf("|%x|",data);
   delay_ms(20);
   output_low(PIN_B3);
   output_high(PIN_B4);
   delay_ms(2000);
   output_low(PIN_B4);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);
   enable_interrupts(global);
Slave:
enum {address,data};
int mode;
BYTE data1 = 0;
BYTE BUFFER;
#int_SSP
SSP_isr()
   BYTE ch;
   if(i2c_poll())
      ch = i2c_read(1);
      if(mode == address)
         mode = data;
         data1 = ch;
         mode = address;
         printf("|%x|", data1);
   else i2c_write(0xEE);
   delay_ms(20);
   output_low(PIN_B4);
   delay_ms(2000);
   output_low(PIN_B4);
   enable_interrupts(INT_SSP);
   mode = address;
So.
I check the send values via Hyper Terminal.
And thats my problem:
At the slave output I am getting permanently the address of the PIC |a0||a0|... and so on and not the |EE||EE|....
And at the master output |ff||ff| ....
Is there something wrong with the routines or do I have to clear the input buffer of the slave PIC? Because I think the code "should" work. I also screened the signal on the scope. And till the write command everything looks fine.
It would be very nice if somebody could help me. I tried it now to long without result. Sad Crying or Very sad
BYE
