Compile problems
Been There
Compile problems
PostPosted: Mon Jan 23, 2006 1:10 am     Reply with quote
I've been using PCM 3.152 for some time now, but I cannot get it to compile lately. It craps out even with projects I've completed in the past. It generally spews the same error, but it makes no sense and even points to a non-existant line of code or a commented line of code.
Error[31] E:\PROJECTS\X-10\X-10DRVR\string.h 25 : Identifier is already used in this scope
The fact is, it isn't already used. The line it points to may be a commented block or a blank line.
What can cause this?
PostPosted: Mon Jan 23, 2006 1:20 am     Reply with quote
Re-install it.
