i'm trying to use the adc of the 18f1320, but i just get zeroes., anyone can help me?
// Funciones
adquirir()
set_adc_channel( 0 );
volt = Read_ADC();
set_adc_channel( 4 );
amp = Read_ADC();
set_adc_channel( 3 );
Vbat = Read_ADC();
set_adc_channel( 2 );
Ibat = Read_ADC();
return 0;
kender
Posted: Sat Jan 21, 2006 4:24 pm
You need to call setup_adc_ports(...) and setup_adc(...) before set_adc_channel(...). You also should add a delay of about 15uS after each call to set_adc_channel(...), that way the voltage will stabilize before you actually read the ADC value.
