Help required urgently !!!!
Zaki
PostPosted: Tue Jan 17, 2006 8:01 am     Reply with quote
Ok now i had my codee burned onto the PIC 18f252 then i used the erase function in the mplab ....
Trying to burn again onto the chip just configure the configuration bits ...
rwyoung
PostPosted: Tue Jan 17, 2006 9:03 am     Reply with quote
Why not just reprogram the chip, including the config bits this time.
Rob Young
Zaki
PostPosted: Sun Jan 22, 2006 11:48 pm     Reply with quote
I dont know how . I got the PIC 18f252 and i wrote code using PCH compiler , then i programmed that code onto the PIC and it was functioning . Then i decided i want to change the code . So i erased that code . Erasing the code just erased with it the past configuration bits and ID . But i aked myself here how come , even if i try putting the old code again i get the same problem ? So i concluded the problem is not with my code its that the configuration bits and Id were somthing already there on the PIC before i put my code . I dont know how to restore them back ??
rwyoung
PostPosted: Mon Jan 23, 2006 8:39 am     Reply with quote
What programmer are you using?
Have you read its manual?
When you look at the HEX file created after compiling you should be able to identify the line(s) with the CONFIG bits. I don't believe it is possible to tell the PCH compilers to exclude them.
You do have a #FUSE statement or statements at the start of your program, right? Look at your code and LST file to be sure the resultant bits are correct.
Rob Young
