jruibarroso
Why doesn't count more than 255 ?? |
Posted: Fri Jan 20, 2006 11:10 am |
I'm working with a 16F877 , made a counter but it don't pass over (seconds) >255 countings, it step to 0..1..2..3..4..255..0..1. Any body can help me with this ?? Thank you ALL
int seconds;
#int_rtcc
clock_isr() {
output_high(LED);
if(--int_count==0)
output_low(LED);
++seconds;
int_count=INTS_PER_SECOND;
Posted: Fri Jan 20, 2006 11:11 am |
Look at what sizes variables can hold.
An _integer_, by default, is an 'int8', and can only hold 0....255.
jruibarroso
Posted: Fri Jan 20, 2006 11:59 am |
ok, thank you very much
but there is another problem...
i changed int seconds; to int16 seconds;
but returns an erros on this line
printf(lcd_putc,"\f %U TEMPERATURA %2U\n", seconds , temp);
do you know why ? |
newguy
Posted: Fri Jan 20, 2006 12:18 pm |
Since 'seconds' is now a long integer (int16), you must use '%lu' not '%u' in your printf statement.
I recommend that you take some time to peruse the manual and/or online help. |
Humberto
Posted: Fri Jan 20, 2006 12:22 pm |
Ok, then you used %U within the string to indicate an unsigned 8 bit variable.
If you defined int16 seconds, printf expect %lu.
Read the CCS Compiler Manual, it will show you the diferent formats for the built-in function printf().
Humberto |
jruibarroso
Posted: Fri Jan 20, 2006 12:43 pm |
THANK you !! ![Very Happy](images/smiles/icon_biggrin.gif) |
