Robi77 Guest
Strange error in printf? |
Posted: Mon Mar 13, 2006 3:19 pm |
Hi!
Have a 18f252 with 20Mhz crystal and this code:
#include "error.h"
unsigned CHAR TxPacket[80];
unsigned CHAR RxPacket[80];
//unsigned CHAR HxPacket[80];
int u;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_oscillator(False);
printf("hello %d",u);
u++;
#include <18F252.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
If i remark the second 80 byte array the program work perfectly. Every second writeout 'hello' and the number. BUT if i use the second array the program will go into crazy, write out this text in FULL speed:
llo -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8hello -1<8
Anybody know why?
Thanks |
Robi77 Guest
Comp version |
Posted: Mon Mar 13, 2006 3:27 pm |
I tried out with 3.245, 3.242, 3.109 |
Posted: Wed Mar 15, 2006 12:59 am |
Is that the entire program that causes the problem or is there more
code that you didn't post ?
It's possible that your code (code that's not posted) is writing past
the end of one of your arrays, and is clobbering some internal variables
used by the compiler. If you did this, it could cause the program to
go berzerk as you are seeing.
Other problems:
You have this fuse:
It's unlikely that you have a LVP programmer, so change it to:
If you leave it as LVP, it could cause your program to lock up.
Here you are specifying 9-bit data:
It's unlikely that your terminal program uses 9 bits. Most are set to
8-bits as the default. Also, no parity is the default. You don't need
to specify it. Finally, it's a good idea to use the ERRORS directive
to prevent the UART from locking up if you get a receive overrun error.
Example:
Code: | #use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,ERRORS) |
