nicenoise
"file version mis-match" error!!!! |
Posted: Thu Jul 01, 2004 10:16 am |
hello...
when i want to compile... the compiler print the error "file version mis-match" and close it...
what's happend???
it's the same for latest versions...
v3.187 and v3.190
help!!!
i cant compile...
n-n ![Sad](images/smiles/icon_sad.gif) |
meop Guest
Posted: Thu Jul 01, 2004 10:26 am |
BUY THE SOFTWARE
It's good software for less money. Use the trial version or the hacked version for a while, and if you like it and find it useful BUY IT!!!
It's worth it. |
dyeatman
File Version Mis-match |
Posted: Thu Jul 01, 2004 11:03 am |
This has happened in the past when the proper files are not in the location the program expects them to be.
See this answer given in the CCS FAQ:
Our license files have a timestamp to prevent an older license file from using a newer version of the compiler. If you have received this error then your license files have become to old to use the recent version of the compiler you have just downloaded or received on disk. This may be quite common for users who download updates from our website but don't replace their registration (license) files with the ones we send to you in the maintenance e-mails.
To fix this problem you need to replace your older registration files with ones we sent to you in our maintenance plan emails. If you cannot find this email then please contact CCS and they will re-send your license files.
manjitpeter
free |
Posted: Mon Dec 26, 2005 8:27 pm |
It's good software for less money. Use the trial version or the hacked version for a while,t's worth it |
manjitpeter
Posted: Mon Dec 26, 2005 8:29 pm |
meop wrote: | BUY THE SOFTWARE
It's worth it. |
manjitpeter
Posted: Mon Dec 26, 2005 8:31 pm |
It's worth it. |
Drolleman Guest
Posted: Tue Dec 27, 2005 7:39 pm |
I have a licenced version and have had this error 3 times this year alone then ccs sends me a new crg file and works again. this is frustrating, the next time i'll hack the program and remove the crg file protection. |
Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
Posted: Wed Dec 28, 2005 6:12 am |
My goodness...the last thing you want to do is make the compiler more buggy by hacking it! |
Posted: Fri Jan 06, 2006 2:13 pm |
It's worth it. |
