Erol Guest
12F683 ADC reading problem. |
Posted: Wed Jan 04, 2006 1:20 am |
i use this code but i cant read ADC,
My compiler version 3.227
i use this code at PIC16C712, and working before.
read_adc(); function is not give a result.
#include "C:\PROGRA~1\PICC\DEVICES\12F683.H"
#device ADC=8
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOPROTECT,NOCPD,NOMCLR, NOFCMEN
#use delay(clock=4000000,restart_wdt)
signed long int duty;
unsigned long int adc_okunan;
unsigned int sonuc=0;
unsigned int sonuc_pwm=0;
unsigned int onceki_sonuc=0;
unsigned int mevcut_pwm=0;
void adc_sonuc()
unsigned int x=0;
unsigned int x_mod=0;
unsigned int1 process=0;
set_adc_channel(0);
delay_us(100);
adc_okunan=read_adc();
while(adc_okunan>3)
adc_okunan-=4;
x++;
x_mod=adc_okunan;
if(x_mod==1 || x_mod==2) { sonuc = x; process=1; }
if(x_mod==0 && onceki_sonuc==(x-1)) {sonuc = x-1; process=1;}
if(x_mod==3 && onceki_sonuc==(x+1)) {sonuc = x+1; process=1;}
if(process==0) sonuc=x;
onceki_sonuc=sonuc;
sonuc_pwm=sonuc*4;
void soft_lineer_pwm()
if(sonuc_pwm>mevcut_pwm) { mevcut_pwm++; delay_ms(7); }
if(sonuc_pwm<mevcut_pwm) { mevcut_pwm--; delay_ms(5); }
set_pwm1_duty((unsigned long int)mevcut_pwm);
return;
disable_interrupts(GLOBAL);
setup_oscillator(OSC_4MHZ);
setup_comparator(7);
setup_port_a(sAN0 || sAN3 || VSS_VDD);
setup_adc(adc_clock_internal);
setup_ccp1(CCP_PWM); // CCP
setup_timer_2(T2_DIV_BY_1, 49, 1); // 20 kHz, 200 F.S.
set_pwm1_duty((unsigned long int)25);
delay_ms(2000);
adc_sonuc();
soft_lineer_pwm();
Posted: Wed Jan 04, 2006 10:09 am |
Here is the comment from the 12F683.H file, which explains
how to use multiple constants in setup_adc_ports:
Quote: | // The following may be OR'ed in with the above using | |
Here is how you are doing it:
Quote: | setup_port_a(sAN0 || sAN3 || VSS_VDD); |
You should compile it both ways and look at the .LST file.
Notice the difference between Logical and Bitwise OR. |
Posted: Thu Jan 05, 2006 4:01 am |
Thanks PCM programmer,
Thats different OR's.
I do mistake. |
