Multiple RS232 port
litoman
Multiple RS232 port
PostPosted: Tue Jan 03, 2006 6:15 am     Reply with quote
I need two serial port in my proyect but the problem is that when i use #int_RDA the pic hang up.It run into the interrupt routine all time and never go out.It seems like a INT_RDA flag not cleared.Here is my code.What is wrong?.
#include <18F252.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BORV45                   //Brownout reset at 4.5V
#FUSES PUT                      //Power Up Timer
#FUSES NOSTVREN                 //Stack full/underflow will not cause reset
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOCPD                    //No EE protection
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=VIEJO)
#use rs232(baud=9600,parity=N,xmit=PIN_C5,rcv=PIN_B0,bits=8,stream=NUEVO)
Main c
#include "c:\Pic\Interfaz Paneles\18F252\Prueba Puertos\INTERFAZ COMUNICACIONES_V1_5.h"
char caracter,caracter2;
#priority EXT,RDA
#define BUFFER_SIZE 20
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_RDA
RDA_isr()
 int t;
   buffer[next_in]=fgetc(VIEJO);
   t=next_in;
   if(next_in==next_out)
   next_in=t;           // Buffer lleno !!
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
#define BUFFER_SIZE2 16
BYTE buffer2[BUFFER_SIZE2];
BYTE next_in2 = 0;
BYTE next_out2 = 0;
/************* INTERRUPCION DEL PUERTO SERIE NUEVO **********************/
#int_EXT
EXT_isr()
  int t2;
   buffer2[next_in2]=fgetc(NUEVO);
   t2=next_in2;
   next_in2=(next_in2+1) % BUFFER_SIZE2;
   if(next_in2==next_out2)
     next_in2=t2;           // Buffer lleno !!
#define bkbhit2 (next_in2!=next_out2)
BYTE bgetc2() {
   BYTE c2;
   while(!bkbhit2) ;
   c2=buffer2[next_out2];
   next_out2=(next_out2+1) % BUFFER_SIZE2;
   return(c2);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_1(T1_DISABLED);
   ext_int_edge(H_TO_L);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_EXT);
   #use fast_io(A)
   #use fast_io(B)
   #use fast_io(C)
   SET_TRIS_A( 0b00111111 );
   SET_TRIS_B( 0xFF );
   SET_TRIS_C( 0b10011111 );
   fprintf(VIEJO,"VIEJO");
   fprintf(NUEVO,"NUEVO");
     if(bkbhit)
         caracter=bgetc();
         fprintf(VIEJO,"%c",caracter);
     if(bkbhit2)
         caracter2=bgetc2();
         fprintf(NUEVO,"%c",caracter2);
I use 3.235 compiler version
