16F684 clk speed setup
russellchung
PostPosted: Mon Jan 02, 2006 4:40 pm     Reply with quote
Hello all,
I have a question on setting up the clk for a 16F684. I need 4 MHz clk using internal RC but the pic wizard gave me some really slow clk. Do I need to use a special fuse to do this ? the following fuses are use:
#include <16F684.h>
#device adc=8
#FUSES NOFCMEN //Fail-safe clock monitor disabled
The assem code seems to know about the delay_us function properly by generating like 5 NOP for a delay of 5 uS. However, on the scope, things are really really slow. it looks like it is running on 32 kHz clk !!!
Any suggestion ?
rc
PostPosted: Mon Jan 02, 2006 5:19 pm     Reply with quote
1. Post a small test program. I need to see what code the Wizard
is inserting, with regard to oscillator setup.
2. Post your compiler version. This will be a number such as 3.191,
or 3.241, etc. It can be found at the start of the .LST file, which
will be in the project folder.
