Configuration bits (words) manual setting? PIC18F6310 bug.
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Tue Jan 03, 2006 6:32 am     Reply with quote
Help! I think I've asked this question ages ago for another part which CCS eventually fixed...but
PIC18LF6310 running at 5v, the compiler:
Configuration Fuses:
   Word  1: 0906   INTRC NOIESO NOFCMEN RESERVED
   Word  2: 1E19   NOBROWNOUT NOWDT BORV21 NOPUT WDT32768
   Word  3: 81C0   BW16 CCP2C1 NOWAIT NOLPT1OSC MCLR RESERVED
   Word  4: 0001   STVREN DEBUG RESERVED NOXINST
   Word  5: 0001   NOPROTECT
   Word  6: 0000
   Word  7: 0001   NOEBTR
the part doesn't have a lower word 1 configuration byte! Hence it reports 0x00 and the compiler expects 0x06! How can I force the compiler to set the lower word 1 byte to 0x00? I've emailed CCS but you guys usually fix things faster!
PostPosted: Tue Jan 03, 2006 11:22 am     Reply with quote
I presume you are actually programming from the compiler?. Otherwise just change the configuration bytes in your programmer.
If you have device editor, the error is caused by the fuses BROWNOUT_SW, and BROWNOUT_NOSL, which have the value in the last column, set to '1', putting them in the first byte, instead of '2'. They therefore don't get masked off by the 'NOBROWNOUT' fuse. Changing this last column value, gives the right result.
You might try a #ROM definition, just setting the word to the required value.
Will Reeve
PostPosted: Tue Jan 03, 2006 3:02 pm     Reply with quote
Hi Ttelmah,
I am using the ICD-U debugger, not even got so far as to get a program finished, it's at the "flash LED" stage to see if the hardware is working!
I've dug into the device editor as suggested and all is now well. It's a shame CCS didn't bother to get back to me as I feel I "pay" them with my maintenance agreement! If you were local I would buy you a pint!
Keep well,
Will
PostPosted: Tue Jan 03, 2006 3:58 pm     Reply with quote
With the number of offers like this I've had recently, I'll be able to stock a bar soon. :-)
They will probably just update the definitions in the next release. Nice for the 'future', but the device editor is a much quicker fix!...
