I Have a problem with the 16F876 pic.
When I read the AN0 analog input which is driven by a 1K potentiometer I can only see a value from 0 to 255 (the variable is of type int). The value I see goes from 0 to 255 3 times when I turn the potentiometer till the end. I use CCS C ver 3.26 and I use the read_adc function and it seems return only the LSB of the 10 bit value. Maybe I must use another function?
I have this device
#device *=16 ADC=10 ICD=TRUE
or
#device *=16 ADC=16 ICD=TRUE
