Crystal question...
KamPutty
Crystal question...
PostPosted: Wed Aug 09, 2006 4:52 pm     Reply with quote
Hi all,
I want to do some 40mhz stuff with my pic18f4520, and I'm using the Software Proto Board that currently has a 20mhz installed.
I'm working with some timer stuff, and need a solution that is stable.
On the can of the 20mhz crystal, it says "20.00000MHZ" and the new crystal I got says "10.000Mhz".
Okay, now for the questions...
Is there really a difference between generic and brand crystils? What should I look for, really? I ordered some 100% based on what I need and got a generic crystal that should/will work....
In other words, I don't want to add more grief in my life because of a bogus crystal!
Thanks!
~Kam (^8*
PostPosted: Wed Aug 09, 2006 5:04 pm     Reply with quote
Here is a thread on the topic:
http://www.ccsinfo.com/forum/viewtopic.php?t=25592
Note that at Digikey you can get exactly what you need.
