Problem with ICD and interrupt
PostPosted: Tue Dec 27, 2005 8:49 pm     Reply with quote
I have enable_interrupts(INT_TIMER1) and enable_interrupts(GLOBAL) set, and when the TMR1IF is set, the program continues normally and doesn't enter to the #int_timer1 routine.
Is a way i can use to see if the program enter to the interrupt routine?
Tanks
PostPosted: Tue Dec 27, 2005 10:22 pm     Reply with quote
Both the Microchip ICD and ICD2 have the limitiation given below.
I assume the CCS ICD is similar. Could this be your problem ?
From the Microchip ICD2 help file:
You cannot single step through an interrupt.
Due to hardware restrictions the MPLAB ICD 2
cannot jump to the interrupt vector memory
location in single step or animate mode.
PostPosted: Wed Dec 28, 2005 5:57 am     Reply with quote
Tanks
