PIN as function parameter...
[mAnNaRo]
PostPosted: Fri Dec 23, 2005 9:42 am     Reply with quote
I need to use costant pin value as parameter in a function
result = Check_Glitch(PIN_A1);
int8 Check_Glitch(int PIN_XX) {
while (input(PIN_XX) && Timeout-- > 0); // COMPILER ERROR
I get compiler error "Expression must evaluate to a constant ::"
How can I resolve?
Tnx
Alex
PostPosted: Fri Dec 23, 2005 9:52 am     Reply with quote
See the do_pin_io() function at the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=25280
