		| Author | Message |
		| nhh
				| ADC-Help me |
				|  Posted: Sun Mar 26, 2006 9:54 pm |   |
				| Hi! I'm studying ADC PIC16F877A.Who can help me?
 Why is there a faulse in this code
  	  | Code: |  	  | #device PIC16F877A *=16 ADC = 10
 Thanks!
		| Ttelmah Guest
				|  Posted: Mon Mar 27, 2006 5:58 am |   |
				| There isn't... However it depends on what else is in the code,and where you put it. To use the standard 'defines', you need:
 #include <16F877A.H>
 as the first line of your code.
 If you then try to set the processor 'type', you will get a complaint, since it is already set in this include file.
 So:
 #device *=16 ADC=10
 As the first two lines of the code, is the normal way of including the standard defines, and setting the options you need.
		| Charlie U
				|  Posted: Mon Mar 27, 2006 7:54 am |   |
				| Also, the compiler doesn't like spaces around the '=' in the device declarations.  You get the "Can't change device type this far into code" error message. |  |
