What is the address from where the PIC begins execution ?
arunb
PostPosted: Thu Dec 22, 2005 12:08 am     Reply with quote
I read that the PIC mcu begins execution from 0 address of the Program Memory, is this correct ??
Is it possible to change this starting address to something using C commands ?? Also how would interrupt service routines be addressed, do ISR's have seperate pre-defined addresses of their own ??
thanks
arunb
kypec
PostPosted: Thu Dec 22, 2005 12:29 am     Reply with quote
Yes, that is correct -> PIC always begins its program execution from address 0x0000 and ISR vectors are generally fixed at 0x0004 (PIC16) or 0x0008 (PIC18).
However, you can relocate your main() and ISR routines with use of the compiler directive
#build(reset=MY_OWN_RESET_ADDRESS,interrupt=MY_OWN_ISR_ADDRESS)
Try to search for the directive above on this forum and you will find plenty of hints and examples Wink
