T6963C Graphic LCD display trouble
PostPosted: Tue Dec 20, 2005 2:28 pm     Reply with quote
Hello.
I am trying to get an 128x64 lcd display based on the T6963C chip to work with an pic16f877
I actually had it working for a while by using some code i found here, but, when i rewired the circut and tested it on a different PIC (16f917), then it suddently stopped working. I have now gone back to the 16f877, but im doing something wrong.... can anyone help?
This is the "driver" that im using:
//// This file contains drivers for using a Tosiba T6963C controller ////
//// in parallel/8080(intel) mode.  The T6963C is 240 pixels across  ////
////  and 64 pixels down. The driver treats the upper left pixel 0,0 ////
////  Connections are as follows:                                    ////
////  /WR - - C4                                                     ////
////  /RD - - C5                                                     ////
////  C//D- - C6                                                     ////
////  /RST- - C7                                                     ////
////  DATA0-7 PORTD0-7                                               ////
////  LCD's FS is tied low (FS = 0 is 8x8 font)                      ////
// 240 x 64 in the 8x8 font mode means that 30 characters across by
// 8 rows of characters may be displayed
#ifndef GLCD_COL
#define GLCD_COL 128    // Used for text wrapping by glcd_text57 function and sanity check
#ifndef GLCD_ROW
#define GLCD_ROW 64    // Used for text wrapping by glcd_text57 function and sanity check
#define set_tris_lcd(x) set_tris_d(x)
#define ON  1
#define OFF 0
#define YES 1
#define NO  0
#define glcd_WriteCmd0(x) glcd_WriteByte(1,x)
#define LCDSetPtr 0x24
#define LCDTxtAdr(x,y) 0x780+(128)+(30*y)+x
//TRIS DataBus=x,  note:control bus (PORTC) always outputs
const int16 TextHome = 0x0000;
const int8  TextArea = 0x0010; // how many bytes before a new line
const int16 GraphicsHome = 0x0101;
const int8  GraphicsArea = 0x0010; // how many bytes before a new line
const int8 AutoModeWrite = 0xB0;
const int8 AutoModeRead  = 0xB1;
const int8 AutoModeReset = 0xB2;
const int8 LCDModeSet  = 0x80;   // send this OR'd with the following
const int8 LCDMode_OR  = 0b0000;
const int8 LCDMode_XOR = 0b0001;
const int8 LCDMode_AND = 0b0010;
const int8 LCDMode_TA  = 0b0100; // TEXT ATTRIBUTE mode.
const int8 LCDMode_RAM = 0b1000; // 1=CG RAM, 0=internal CG ROM
const int8 LCDSetCursorPtr  = 0x21;  // cursor address
const int8 LCDSetCursorSize = 0xA0;  // 1 line cursor
const int8 LCDDispMode = 0x90;   // send this OR'd with the following
const int8 LCDDisp_BLK = 0b0001;
const int8 LCDDisp_CUR = 0b0010;
const int8 LCDDisp_TXT = 0b0100;
const int8 LCDDisp_GRH = 0b1000;
const int1 LCDFont = 0;//FS pin has internal pull-up. FS=1 unless grounded
const int8 LCDField = 8; //CAMBIO:8 POR 6 //FS=1 then field=6. FS=0 then field=8
const int8 LCDCharWidth = GLCD_COL /LCDField;
const int16 CharPerScn= LCDCharWidth*16; //CAMBIO: 16 por 8 //number of characters on a screen
struct lcd_pin_def
   BOOLEAN unused1;    // C0
   BOOLEAN unused2;    // C1
   BOOLEAN unused3;  // C2
   BOOLEAN unused4;  // C3
   BOOLEAN w_bar;  // C4 Write bar active low
   BOOLEAN r_bar;  // C5 Read bar active low
   BOOLEAN cd;         // C6 Command/Data BAR   1=command 0=data
   BOOLEAN reset_bar;  // C7 Reset active low
   int  data    :  8;  // PortD=Data bus
struct lcd_pin_def  LCD;
#byte LCD = 0x07    // portC address on 18F877
int   glcd_ReadByte(void);
void  glcd_WriteByte(int1 cd, int data);
void  glcd_WriteByteAuto(int data);
void  glcd_WriteCmd2(int16 data, int cmd);
void  glcd_WriteCmd1(int data, int cmd);
void  glcd_gotoxy(int x, int y, int1 text);
void glcd_clr(int16 location, int16 size);
int16 ERRORS;
//BOOLEAN glcd_pixel(unsigned int x,unsigned int y, int1 color);
// Purpose: Clears LCD RAM
void glcd_clr(int16 location,int16 size)
glcd_WriteCmd2(location,LCDSetPtr);
glcd_WriteCmd0(AutoModeWrite);
for (;size;size--)
glcd_WriteByteAuto(0x00);//clear ram
glcd_WriteCmd0(AutoModeReset);
// Purpose:       Turn a pixel on a graphic LCD on or off
// Inputs:        x - the x coordinate of the pixel
//                y - the y coordinate of the pixel
//                color - ON or OFF
// Output:        1 if coordinate out of range, 0 if in range
glcd_pixel(int16 x,int16 y, int1 color)
  int8 r=0,c=0;
  c=color;//converting booean to an int8
  if (x>=GLCD_COL)
    bit_set(ERRORS,5);//ERRORS=bit 5. LCD x range exceeded
    return (FALSE);
  if (y>=GLCD_ROW)
    bit_set(ERRORS,6);//ERRORS=bit 6. LCD y range exceeded
    return (FALSE);
r=fmod(x,8);
  glcd_WriteCmd2(GraphicsHome+(y*16+(x/8)),LCDSetPtr);
  glcd_WriteCmd0(0xf0|(c<<3) |(7-r));
// Purpose:       Draw a line on a graphic LCD using Bresenham's
//                line drawing algorithm
// Inputs:        (x1, y1) - the start coordinate
//                (x2, y2) - the end coordinate
// Dependencies:  glcd_pixel()
void glcd_line(int x1, int y1, int x2, int y2, int1 color)
  signed int  x, y, addx, addy, dx, dy;
  signed long P;
  int i;
  dx = abs((signed int)(x2 - x1));
  dy = abs((signed int)(y2 - y1));
  x = x1;
  y = y1;
  if(x1 > x2)
    addx = -1;
    addx = 1;
  if(y1 > y2)
    addy = -1;
    addy = 1;
  if(dx >= dy)
    P = 2*dy - dx;
    for(i=0; i<=dx; ++i)
      glcd_pixel(x, y, color);
      if(P < 0)
        P += 2*dy;
        x += addx;
        P += 2*dy - 2*dx;
        x += addx;
        y += addy;
    P = 2*dx - dy;
    for(i=0; i<=dy; ++i)
      if(P < 0)
        P += 2*dx;
        y += addy;
        P += 2*dx - 2*dy;
        x += addx;
        y += addy;
// Purpose:       Draw a rectangle on a graphic LCD
//                fill  - YES or NO
// Dependencies:  glcd_pixel(), glcd_line()
void glcd_rect(int x1, int y1, int x2, int y2, int fill, int1 color)
  if(fill)
    int y, ymax;                          // Find the y min and max
    if(y1 < y2)
      y = y1;
      ymax = y2;
      y = y2;
      ymax = y1;
    for(; y<=ymax; ++y)                    // Draw lines to fill the rectangle
    glcd_line(x1, y, x2, y, color);
    glcd_line(x1, y1, x2, y1, color);      // Draw the 4 sides
    glcd_line(x1, y2, x2, y2, color);
    glcd_line(x1, y1, x1, y2, color);
    glcd_line(x2, y1, x2, y2, color);
// Purpose:       Draw a bar (wide line) on a graphic LCD
//                width  - The number of pixels wide
void glcd_bar(int x1, int y1, int x2, int y2, int width, int1 color)
  signed int  x, y, addx, addy, j;
  signed long P, dx, dy, c1, c2;
  int i;
  x = x1;
  y = y1;
  c1 = -dx*x1 - dy*y1;
  c2 = -dx*x2 - dy*y2;
  if(x1 > x2)
    addx = -1;
    c1 = -dx*x2 - dy*y2;
    c2 = -dx*x1 - dy*y1;
  addx = 1;
  if(y1 > y2)
    addy = -1;
  addy = 1;
  if(dx >= dy)
    P = 2*dy - dx;
      for(j=-(width/2); j<width/2+width%2; ++j)
        if(dx*x+dy*(y+j)+c1 >= 0 && dx*x+dy*(y+j)+c2 <=0)
        glcd_pixel(x, y+j, color);
      if(P < 0)
        P += 2*dy;
        x += addx;
        P += 2*dy - 2*dx;
        x += addx;
        y += addy;
    P = 2*dx - dy;
      if(P < 0)
        P += 2*dx;
        y += addy;
        P += 2*dx - 2*dy;
        x += addx;
        y += addy;
          glcd_pixel(x+j, y, color);
// Purpose:       Draw a circle on a graphic LCD
// Inputs:        (x,y) - the center of the circle
//                radius - the radius of the circle
//                fill - YES or NO
void glcd_circle(int x, int y, int radius, int1 fill, int1 color)
  signed int a, b, P;
  a = 0;
  b = radius;
  P = 1 - radius;
  do
    if(fill)
      glcd_line(x-a, y+b, x+a, y+b, color);
      glcd_line(x-a, y-b, x+a, y-b, color);
      glcd_line(x-b, y+a, x+b, y+a, color);
      glcd_line(x-b, y-a, x+b, y-a, color);
      glcd_pixel(a+x, b+y, color);
      glcd_pixel(b+x, a+y, color);
      glcd_pixel(x-a, b+y, color);
      glcd_pixel(x-b, a+y, color);
      glcd_pixel(b+x, y-a, color);
      glcd_pixel(a+x, y-b, color);
      glcd_pixel(x-a, y-b, color);
      glcd_pixel(x-b, y-a, color);
    if(P < 0)
      P+= 3 + 2*a++;
      P+= 5 + 2*(a++ - b--);
  } while(a <= b);
void glcd_init(void) {
  int16 counter;
  set_tris_lcd(0xff);   //TRIS DATA bus,note:control bus always outputs
  LCD.w_bar = 1;      // INITIAL STATES OF CONTROL PINS
  LCD.r_bar = 1;      //
  LCD.cd = 1;         // command
  LCD.reset_bar = 0;  // perform a reset
  delay_us(20);      // delay for a reset
  LCD.reset_bar = 1;  // run
  // Set up the graphics and text areas
  glcd_WriteCmd2(TextHome, 0x40);
  glcd_WriteCmd2(TextArea, 0x41);
  glcd_WriteCmd2(GraphicsHome, 0x42);
  glcd_WriteCmd2(GraphicsArea, 0x43);
  // set address to 0
  glcd_WriteCmd2(0x0000, 0x24);
  // Clear all RAM of LCD (8k)
  glcd_WriteByte(1, AutoModeWrite);
  for (counter = 0; counter < 0x1fff; counter++)
    glcd_WriteByteAuto(0);    // fill everything with zeros
  glcd_WriteByte(1, AutoModeReset);
    int status = 0, temp = 0;
    set_tris_lcd(0xff);
    LCD.w_bar = 1;
    LCD.r_bar= 1;
    LCD.cd = 1;//defaults
    while (status != 0x03) {  // is LCD busy?
       LCD.r_bar= 0;
       temp = LCD.data;
       LCD.r_bar = 1;
       status = temp & 0x03;
    set_tris_lcd(0x00);    // All outputs
    LCD.cd = cd;           // Command/Data bar
    LCD.data = data;
    LCD.r_bar = 1;         // not read
    LCD.w_bar = 0;         // write
    LCD.w_bar = 1;         // release
   int status = 0, temp = 0; // status bits ARE DIFFERENT BITS THAN NORMAL
   set_tris_lcd(0xff);
   LCD.w_bar = 1;
   LCD.r_bar = 1;
   LCD.cd = 1; // defaults
   while (status != 0x08) {  // is LCD busy?
     LCD.r_bar = 0;
     temp = LCD.data;
     LCD.r_bar = 1;
     status = temp & 0x08;
   LCD.cd = 0;             // This is always data, cd=0
   LCD.data = data;        // Put data on data bus
  glcd_WriteByte(0, data);
  glcd_WriteByte(1, cmd);
  glcd_WriteByte(0, data & 0xff);
  glcd_WriteByte(0, data>>8);
  int data = 0, status = 0, temp = 0;
  set_tris_lcd(0xff);
  LCD.w_bar = 1;
  LCD.r_bar = 1;
  #asm nop #endasm
    LCD.r_bar = 0;
    temp = LCD.data;
    LCD.r_bar = 1;
  LCD.cd = 0;          // Command/Data bar
  LCD.r_bar = 0;        // read
  #asm nop #endasm    // THIS PAUSE IS VERY NESSESARY !!!//
  data = LCD.data;
  LCD.r_bar = 1;
  LCD.cd = 1;
  return data;        // Return the read data
void glcd_putc(char c) {
   glcd_WriteCmd1(c - 0x20, 0xc0);
void glcd_gotoxy(int x, int y, int1 text) { // sets memory location to screen location x, y
   // location 1,1 is upper left corner;  text = 1 (text area), text = 0 (graphics area)
   int16 location, home;
   int line;
   if (!text) {
      home = GraphicsHome;
      line = GraphicsArea;
   else {
      home = TextHome;
      line = TextArea;
   location = home + (((int16)y - 1) * line) + x - 1;
   glcd_WriteCmd2(location, 0x24);
const BYTE TEXT[51][5] ={ 0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
                          0x00, 0x00, 0x5F, 0x00, 0x00, // !
                          0x00, 0x03, 0x00, 0x03, 0x00, // "
                          0x14, 0x3E, 0x14, 0x3E, 0x14, // #
                          0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
                          0x43, 0x33, 0x08, 0x66, 0x61, // %
                          0x36, 0x49, 0x55, 0x22, 0x50, // &
                          0x00, 0x05, 0x03, 0x00, 0x00, // '
                          0x00, 0x1C, 0x22, 0x41, 0x00, // (
                          0x00, 0x41, 0x22, 0x1C, 0x00, // )
                          0x14, 0x08, 0x3E, 0x08, 0x14, // *
                          0x08, 0x08, 0x3E, 0x08, 0x08, // +
                          0x00, 0x50, 0x30, 0x00, 0x00, // ,
                          0x08, 0x08, 0x08, 0x08, 0x08, // -
                          0x00, 0x60, 0x60, 0x00, 0x00, // .
                          0x20, 0x10, 0x08, 0x04, 0x02, // /
                          0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
                          0x04, 0x02, 0x7F, 0x00, 0x00, // 1
                          0x42, 0x61, 0x51, 0x49, 0x46, // 2
                          0x22, 0x41, 0x49, 0x49, 0x36, // 3
                          0x18, 0x14, 0x12, 0x7F, 0x10, // 4
                          0x27, 0x45, 0x45, 0x45, 0x39, // 5
                          0x3E, 0x49, 0x49, 0x49, 0x32, // 6
                          0x01, 0x01, 0x71, 0x09, 0x07, // 7
                          0x36, 0x49, 0x49, 0x49, 0x36, // 8
                          0x26, 0x49, 0x49, 0x49, 0x3E, // 9
                          0x00, 0x36, 0x36, 0x00, 0x00, // :
                          0x00, 0x56, 0x36, 0x00, 0x00, // ;
                          0x08, 0x14, 0x22, 0x41, 0x00, // <
                          0x14, 0x14, 0x14, 0x14, 0x14, // =
                          0x00, 0x41, 0x22, 0x14, 0x08, // >
                          0x02, 0x01, 0x51, 0x09, 0x06, // ?
                          0x3E, 0x41, 0x59, 0x55, 0x5E, // @
                          0x7E, 0x09, 0x09, 0x09, 0x7E, // A
                          0x7F, 0x49, 0x49, 0x49, 0x36, // B
                          0x3E, 0x41, 0x41, 0x41, 0x22, // C
                          0x7F, 0x41, 0x41, 0x41, 0x3E, // D
                          0x7F, 0x49, 0x49, 0x49, 0x41, // E
                          0x7F, 0x09, 0x09, 0x09, 0x01, // F
                          0x3E, 0x41, 0x41, 0x49, 0x3A, // G
                          0x7F, 0x08, 0x08, 0x08, 0x7F, // H
                          0x00, 0x41, 0x7F, 0x41, 0x00, // I
                          0x30, 0x40, 0x40, 0x40, 0x3F, // J
                          0x7F, 0x08, 0x14, 0x22, 0x41, // K
                          0x7F, 0x40, 0x40, 0x40, 0x40, // L
                          0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
                          0x7F, 0x02, 0x04, 0x08, 0x7F, // N
                          0x3E, 0x41, 0x41, 0x41, 0x3E, // O
                          0x7F, 0x09, 0x09, 0x09, 0x06, // P
                          0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
                          0x7F, 0x09, 0x09, 0x09, 0x76};// R
const BYTE TEXT2[44][5]={ 0x26, 0x49, 0x49, 0x49, 0x32, // S
                          0x01, 0x01, 0x7F, 0x01, 0x01, // T
                          0x3F, 0x40, 0x40, 0x40, 0x3F, // U
                          0x1F, 0x20, 0x40, 0x20, 0x1F, // V
                          0x7F, 0x20, 0x10, 0x20, 0x7F, // W
                          0x41, 0x22, 0x1C, 0x22, 0x41, // X
                          0x07, 0x08, 0x70, 0x08, 0x07, // Y
                          0x61, 0x51, 0x49, 0x45, 0x43, // Z
                          0x00, 0x7F, 0x41, 0x00, 0x00, // [
                          0x02, 0x04, 0x08, 0x10, 0x20, // \
                          0x00, 0x00, 0x41, 0x7F, 0x00, // ]
                          0x04, 0x02, 0x01, 0x02, 0x04, // ^
                          0x40, 0x40, 0x40, 0x40, 0x40, // _
                          0x00, 0x01, 0x02, 0x04, 0x00, // `
                          0x20, 0x54, 0x54, 0x54, 0x78, // a
                          0x7F, 0x44, 0x44, 0x44, 0x38, // b
                          0x38, 0x44, 0x44, 0x44, 0x44, // c
                          0x38, 0x44, 0x44, 0x44, 0x7F, // d
                          0x38, 0x54, 0x54, 0x54, 0x18, // e
                          0x04, 0x04, 0x7E, 0x05, 0x05, // f
                          0x08, 0x54, 0x54, 0x54, 0x3C, // g
                          0x7F, 0x08, 0x04, 0x04, 0x78, // h
                          0x00, 0x44, 0x7D, 0x40, 0x00, // i
                          0x20, 0x40, 0x44, 0x3D, 0x00, // j
                          0x7F, 0x10, 0x28, 0x44, 0x00, // k
                          0x00, 0x41, 0x7F, 0x40, 0x00, // l
                          0x7C, 0x04, 0x78, 0x04, 0x78, // m
                          0x7C, 0x08, 0x04, 0x04, 0x78, // n
                          0x38, 0x44, 0x44, 0x44, 0x38, // o
                          0x7C, 0x14, 0x14, 0x14, 0x08, // p
                          0x08, 0x14, 0x14, 0x14, 0x7C, // q
                          0x00, 0x7C, 0x08, 0x04, 0x04, // r
                          0x48, 0x54, 0x54, 0x54, 0x20, // s
                          0x04, 0x04, 0x3F, 0x44, 0x44, // t
                          0x3C, 0x40, 0x40, 0x20, 0x7C, // u
                          0x1C, 0x20, 0x40, 0x20, 0x1C, // v
                          0x3C, 0x40, 0x30, 0x40, 0x3C, // w
                          0x44, 0x28, 0x10, 0x28, 0x44, // x
                          0x0C, 0x50, 0x50, 0x50, 0x3C, // y
                          0x44, 0x64, 0x54, 0x4C, 0x44, // z
                          0x00, 0x08, 0x36, 0x41, 0x41, // {
                          0x00, 0x00, 0x7F, 0x00, 0x00, // |
                          0x41, 0x41, 0x36, 0x08, 0x00, // }
                          0x02, 0x01, 0x02, 0x04, 0x02};// ~
// Purpose:       Write text on a graphic LCD
// Inputs:        (x,y) - The upper left coordinate of the first letter
//                textptr - A pointer to an array of text to display
//                size - The size of the text: 1 = 5x7, 2 = 10x14, ...
void glcd_text57(int x, int y, char* textptr, int size, int1 color)
  const BYTE bytes_per_char=5;
  int i, j, k, l, m;                     // Loop counters
  BYTE pixelData[bytes_per_char];                     // Stores character data
  for(i=0; textptr[i] != '\0'; ++i, ++x) // Loop through the passed string
    if(textptr[i] < 'S') // Checks if the letter is in the first or second array
    memcpy(pixelData, TEXT[textptr[i]-' '], bytes_per_char);
    else if(textptr[i] <= '~') // Check if the letter is in the second array
    memcpy(pixelData, TEXT2[textptr[i]-'S'], bytes_per_char);
    memcpy(pixelData, TEXT[0], bytes_per_char);   // Default to space
    if(x+5*size >= GLCD_COL)          // Performs character wrapping
      x = 0;                           // Set x at far left position
      y += 7*size + 1;                 // Set y at next position down
    for(j=0; j<bytes_per_char; ++j, x+=size)         // 5 bytes per character
      for(k=0; k<7*size; ++k)          // Loop through the vertical pixels
        if(bit_test(pixelData[j], k)) // Check if the pixel should be set
          for(l=0; l<size; ++l)      // The next two loops change the
          {                          // character's size
            for(m=0; m<size; ++m)
              glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
And this is the main:
#include  <16F877A.H>
#fuses    XT,NOBROWNOUT,NOWDT,NOPROTECT
#use      delay (clock=4000000)
#include "math.h"
#include "glcd.c"
#use fast_io(D)
   while(true)
   output_high(pin_a1);
   output_low(pin_a1);
      set_tris_c(0x00);  // graphic lcd control lines all output
   glcd_init();
   glcd_WriteByte(1, (LCDModeSet|LCDMode_XOR));
   glcd_WriteByte(1, (LCDDispMode|LCDDisp_TXT|LCDDisp_GRH));
   glcd_gotoxy(3,2,1);
   glcd_putc("Hello");
The "output_high(pin_a1);" part is just to check if the pic is up and running. When i connect a mulitmeter to pin_a1 it goes high and then low. But then it stops. If i remove the lcd initialization routine, then it works..(pin_a1 high and low evey second) So the pic hangs somewhere..
Really need some help here...
Thanks in advance
LTS
PostPosted: Tue Dec 20, 2005 3:11 pm     Reply with quote
A few obvious comments:
1. Are you using a Low Voltage programmer ? If not, add NOLVP
to the end of the #fuses statement. Programmers such as
PicStart-Plus, ICD2, CCS ICD, Warp-13a and MachX are High Voltage
programmers, and the NOLVP setting should be used with them.
2. You have placed the "#use fast_io(D)" statement after the
#include "glcd.c" statement. This means that the LCD driver
will not use fast i/o. Remember, the fast_io() statement only
applies to code that comes after it in the file.
See the corrections shown below:
#fuses XT,NOBROWNOUT,NOWDT,NOPROTECT, NOLVP
#include "math.h"
#use fast_io(D)
#include "glcd.c"
while(true)
output_low(pin_a1);
glcd_init();
glcd_gotoxy(3,2,1);
glcd_putc("Hello");
LTS
PostPosted: Tue Dec 20, 2005 3:23 pm     Reply with quote
Hello
Thanks for suggestions, but it didn't change anything.. The LCD shows nothing... i can change contrast and everything but no text appears....What could cause the pic to hang in the lcd routine??
PostPosted: Tue Dec 20, 2005 4:10 pm     Reply with quote
You need to determine what line of code is causing the program to hang.
If you have a debugger such as ICD2, you can click on the Run button
and then after it's apparent that the program is hanging, you can click
on the halt button. In MPLAB a green arrow will point to the line of
C source code where the program is hanging.
If you don't have a debugger, you can use putc() statements to track
the progress of your code, and to show where it hangs. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=21949&highlight=putc
treitmey
PostPosted: Tue Dec 20, 2005 4:33 pm     Reply with quote
This driver was based on work I did. So I am familiar with it.
Try something simple. init.
Do 1 init filling with 0x00 and wait 1sec and do another filling with 0xFF.
If that doesn't work check the timing of the #asm noop #endasm.
Also double check your ports. Looks like you want to use the port C.
But there is a #define that sets the tris and its using D.
And in main your using fastio on D.
Double check the ports.
LTS
PostPosted: Tue Dec 20, 2005 5:44 pm     Reply with quote
I've triple checked the wires several times, but now i resoldered everything with new wires... and guess what.. IT WORKS! great. Thanks!
