Why PCH(Ver3.240) is NG if dot activate(Registration) ?
Japan_Yokohama
PostPosted: Wed Jan 11, 2006 1:09 am     Reply with quote
PCH installed is Ok with Janpanese Windows XP Pro , but CCS version is space . and when try complier simple program , it is non stop for roop .
PostPosted: Wed Jan 11, 2006 2:30 am     Reply with quote
Look at the CCS versions page. It's possible that your version
has this problem:
3.239 Resolved some problems with the power PWM initialization
3.239 Some menu items grayed out in the PCW IDE are fixed
3.240 Minor code generation and optimization changes
3.241 A problem installing on systems with international date formats is fixed
3.241 A serious optimization bug (introduced in 3.240) is fixed
3.242 Internal changes to support version 4 resulted in minor code generation and optimization changes
3.242 A bug in MAKE16 sometimes causing nearby statements to fail is fixed
If you are a registered owner of the compiler, download the latest
version if you can. If you can't download it, then send an email to
CCS support and explain how vs. 3.240 doesn't install correctly for you,
and ask if they will let you download the latest version. Include your
customer reference number in the email. This page has the email
address for CCS support:
http://www.ccsinfo.com/techsupport.shtml
