Seba Guest
Help please. If i set 1 bit of port E 3 pins go high.... |
Posted: Wed Dec 14, 2005 11:35 pm |
i am having a problem with a device i built and have a major deadline for soon.
The code is very simple, basically i have 20 output ports, on a 18F8627 connected to external devices (LEDs) and they are turned on by a lookup table.
I was testing the device but the first 4 LEDs are connected to pins 4-7 of PORT E. I am able to turn on the one connected to E7, but every time i set any of E4, E5 or E6 they all go high together.
I am setting the whole port together, rather than individual pins with the following instruction:
output_e(frames[FE][whichFrame]) ;
I have similar instructions for LEDs connected to PORT J and D and they work perfectly.
Appreciate any help
Thanks in advance.
Sebastian |
Posted: Thu Dec 15, 2005 12:28 am |
Disable the External Memory Bus. It's enabled by default upon reset.
Add the code shown in bold, below:
Quote: | #include <18F8627.H>
#byte MEMCON = 0xF9C
#bit EBDIS_BIT = MEMCON.7
EBDIS_BIT = 1; // Disable external memory bus
