spikit_uk
Setting up 16F88 with external 20MHz oscillator |
Posted: Sun Dec 11, 2005 4:07 pm |
Hi guys, sorry this is such a fundamental question. I have searched for an answer previously posted, and I apologise if I have missed it.
I am just wondering if anyone has any advice on setting up a 16F88 with an external 20MHz oscillator.
So far I have
#fuses EC_IO, HS, NOWDT, NOLVP, NOMCLR, NOPUT
Do I need to set the osccon to anything? Also I am doing this on breadboard with a 2pin crystal, am I right in connecting both pins to 0V with very small capacitors (eg 15nf)? Is the breadboard likely to give me trouble at these speeds?
Many thanks for any help you can offer guys, thankyou
Tom |
Humberto
Posted: Sun Dec 11, 2005 6:07 pm |
No, it's wrong. Here you will find how to connect the crystal to a PIC.
http://www.mikroelektronika.co.yu/english/product/books/PICbook/2_02chapter.htm
Lets assume that a breadboard is not the best choise for high freq, it should run ok
but keepping the wires as short as possible.
Humberto |
spikit_uk
Posted: Mon Dec 12, 2005 6:15 am |
Hi again guys, many thanks for your help and links.
I think it is actually a two pin crystal; a CMAC CK.
Humberto, your link does seem to suggest typing both pins to 0v with capacitors; although I was a few orders of magnitude out with 15nF; as the link seems to suggest 30pF!
I may switch to a 3pin with internal capacitors for simplicity however.
So can you guys by any chance suggest a fuse/osccon configuration for such a system?
Thanks again fellas, Tom |
Posted: Mon Dec 12, 2005 6:50 am |
If it is a two pin crystal, then the mode _must_ be HS, not 'EC', or 'EC_IO'. These latter modes are for external _oscillators_. Now the capacitor value that should be used, will depend on the crystal, and should be specified by the manufacturer. In fact it'll probably run OK, with the capacitor fairly well 'out of spec', but this will cause the frequency to be out of the manufacturers specification. If you get the value 'right' (and remember that you also have to include the capacitance of the pin, and the traces in the calculation - with a 'breadboard', the latter may well already be larger than required...),the crystal will then give it's specified accuracy.
Basically the oscillator modules, are normally for pin devices, with only three connected. They have a crystal, and solid state oscillator/buffer all built into the one package, and produce a square wave output that can be fed directly into the 'OSC1/CLKIN' pin. For these, EC, or EC_IO, are the right fuse settings (the former produces a clock output on OSC2, that can be used to feed other devices, the latter makes this pin available for I/O.
Humberto
Posted: Mon Dec 12, 2005 7:27 am |
I preffer to show a circuit.
The phrase:
"connecting both pins to 0V with very small capacitors"
sound quite confusing to me.
Pls read the datasheet.
You will find all you are asking in Page 35,
4.0 OSCILLATOR CONFIGURATIONS
If you are going to use a crystal like this one (thanks PCM Programmer)
http://rocky.digikey.com/WebLib/ECS/Web%20Photos/HC-49US.jpg
....your header should look like this:
#include <16F88.h>
#device adc=8 // or #device adc=10
#FUSES HS //High speed Osc (> 4mhz)
#FUSES PUT //Power Up Timer
#FUSES NOLVP //No low voltage prgming, B3(PIC16)
#use rs232(baud=9600,parity=N,xmit=PIN_A3,rcv=PIN_A2,ERRORS)
// Select according to yours need.
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(VREF_LOW|-2);
setup_oscillator(False);
// your code
Hope this help.
Humberto |
spikit_uk
Posted: Tue Dec 13, 2005 4:26 pm |
Thankyou so much again guys, you're fab.
Things are working fine now, I was just getting a bit confused. I apologise that I was a little unspecific about certain things. All the best
T |
