tvnorm Guest
interupt on change porta |
Posted: Sun Dec 11, 2005 4:40 pm |
I have been reading up on interrupts on the forum, and based on my findings I have come up with the following code, which is mainly based on newguys keypad routine. I simply want to light an LED on port b for a second whenever a button is pressed on port a. It doesnt' seem to want to work. I checked the.LST file, and it seems to be clearing the interrupt flag after the interrupt routine, but im still new to this and can only just about follow whats going on.
Any Suggestions?
//PIC CONFIGURATION
#include <16F690.H>
#fuses XT, NOWDT, NOPROTECT, NOPUT, NOBROWNOUT, NOMCLR
#use delay(clock = 4000000) //base delay times on a 4MHz Xtal
//FUNCTIONS AND LABELS
void light_led(void);
void PORTA_ISR(void);
//DEFINES
#byte PORTA = 5
#byte PORTB = 6 //PIC b portb (6) replaced by string PORTB
//VARIABLES and CONSTANTS
int1 button;
static int prior_porta_state;
//CODE
disable_interrupts(INT_RA);
PORTB = 0xFF;
PORTB=0;
PORTA = prior_porta_state;
enable_interrupts(INT_RA);
#INT_RA
if (prior_porta_state != PORTA)
prior_porta_state = PORTA;
button = TRUE;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
//setup_timer_0(RTCC_INTERNAL);
//setup_timer_1(T1_DISABLED);
//setup_timer_2(T2_DISABLED,0,1);
//setup_spi(FALSE);
setup_oscillator(OSC_4MHZ);
set_tris_a(0xFF);
PORTA=0;
port_a_pullups(TRUE);
delay_us(10);
button = FALSE;
set_tris_b(0x00);
PORTB = 0;
prior_porta_state=PORTA;
while(1) //hangs here until an interrrupt then returns?
if(button==TRUE)
button = FALSE;
light_led();
tvnorm Guest
Posted: Sun Dec 11, 2005 7:56 pm |
Well, in case anyone is interested, a little more digging cleared it up. Hopefully another beginner can benefit from this, or someone else can laugh at it.
I erroneously thought that
Would register any interrupt on PORTA- it doesn't appear to do anything.
(other than as in #INT_RA)
However,
enable_interrupts(INT_RA0|INT_RA1|INT_RA2|INT_RA3|INT_RA4|INT_RA5);
Works as I wanted it too, with the added bonus being able to mask whatever inputs I want!! |
