kg6vkg
Problems with Full Bridge Configuration |
Posted: Sat Dec 10, 2005 2:50 am |
I am new to the CCS compiler and am having trouble setting up a full bridge controller.
Setup:
Compiler: PCWH 3.239
Chip: 18F4520
ICD: ICD-U40
I can't seem to get the Full Bridge PWM to work using the following code:
#include "D:\CCS\test4520B\PWM.h"
#define GREEN_LED PIN_A0
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_timer_2(T2_DIV_BY_4,140,1);
setup_vref(FALSE);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
setup_ccp1(CCP_PWM_FULL_BRIDGE|CCP_SHUTDOWN_AC_H|CCP_SHUTDOWN_BD_L);
set_pwm1_duty(70);
while(true)
output_low (GREEN_LED);
delay_ms (100);
output_high (GREEN_LED);
delay_ms (100);
When I run this code nothing happens. The ECCP never seems to iniatialize.
I have implemented the ECCP full bridge in assembler before, but I was hoping that the above library function would set everything up for me and save a lot of time. When I watch in the debug menu it never writes to the CCP1CON register, which makes me think that I am not calling or initializing the function correctly. I read another posting:
http://www.ccsinfo.com/forum/viewtopic.php?t=23896&sid=66d21b94d00ac39f584746fa518d0487
He seemed to set the ECCP manually just like I have in assembler.
Is there a better way? Where am I supposed to go to find literature on how to use the ECCP functions within CCS? The "C Compiler" book that came with the software does not seem to cover this feature in much detail. Is there some other document that I am not looking at?
Thanks for your time, Mark. |
Posted: Sat Dec 10, 2005 1:16 pm |
I don't think CCS is setting it up correctly.
Here is the .LST file code:
Code: | .... setup_ccp1(CCP_PWM_FULL_BRIDGE|CCP_SHUTDOWN_AC_H|CCP_SHUTDOWN_BD_L);
0018: MOVLW B7
001A: ANDWF FB1,F // T3CON.3 and T3CON.6 = 0: Use Timer 1
001C: BSF F94.2 // TRISC.2 = 1: Set pin C2 = input
001E: CLRF FBD // CCP1CON = 0
0020: MOVLW 40
0022: MOVWF FBD // CCP1CON = 0x40: Full Bridge forward mode
But the data sheet says for the Full Bridge mode:
Quote: | The TRISC<2> and TRISD<7:5> bits must be cleared to
make the P1A, P1B, P1C and P1D pins outputs. |
They are setting TRISC.2 = 1 (it should be set = 0), and they're
not setting TRISD.5, 6, and 7 = 0 (They come up from reset = 1).
So the TRIS needs to be fixed. You can do that with the set_tris_x()
functions. |
