Sampling an 8 bit WAV file with a PIC
Spiffy
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue Feb 10, 2004 12:44 pm     Reply with quote
Hey! spam -- ignore this post to all the interestee`! Smile
How would I sample a 8 bit audio WAV file through my PIC and have good sound fidelity?
heres what I cam up with:
#include "16f877.h"
#include "stdlib.h"
#use delay (clock=4000000)
#use rs232 (baud=9600,xmit=pin_c6,rcv=pin_c7)
#bit CKE = 0x94.6
#bit SMP = 0x94.7
#bit CKP = 0x14.4
#byte SSPSTAT=0x94
#byte SSPCON=0x14
#bit ADFM=0x9f.7
//Déclaration des variables
char choix;
int data=0,yx,res2;
long int i=0,resultat;
void son (void);
void ecriture (void);
void lecture (void);
void conversion (void);
void main (void)
set_tris_C(0x90); //configure les ports pour sortie et entree.
set_tris_A(0xff);
set_tris_E(0x04);
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_internal);
ADFM=1;
setup_spi(spi_master|spi_l_to_h|spi_clk_div_4);
CKE = 1; // donnée VALIDE de front descendant à front descendant
CKP = 0; // La mémoire échantillone sur front montant
SMP = 0; // Échantillonage au centre d'un créneau
i=0;
Printf("\n\r 1-Pour faire une simple ecriture");
Printf("\n\r 2-Pour faire une lecture");
Printf("\n\r 3-Pour faire une conversion AD");
Printf("\n\r 4-Pour faire jouer un son");
choix=getch();
if (choix=='1')
ecriture();
if (choix=='2')
lecture();
if (choix=='3')
conversion();
if (choix=='4')
son();
puts("\n\r Erreur");
printf("\n\r appuyer sur UN chiffre:");
yx=getch();
printf("\n\rlecture:%d",yx);
getch();
output_low(pin_a4); //On choisi la memoire
spi_write(0x06); //Write enable
output_high(pin_a4);
output_low(pin_a4);
spi_write(0x02); //on veut ecrire sur la memoire
spi_write(0x00); //On choisi l'adress 1
spi_write(0x00); //On choisi l'adress 2
While(i<70)
spi_write(yx); //On designe le data a envoyer
i++;
output_high(pin_a4); //On enleve la selection de memoire
printf("\n\r ok!");
void lecture (void)
printf("\n\r SSPSTAT:%x",SSPSTAT);
printf("\n\r SSPSTAT:%x",SSPCON);
printf("\n\rReading...");
output_low(pin_a4);
spi_write(0x03);
spi_write(0x00);
spi_write(0x00);
While(i<80)
data=spi_read(0);
printf("\n\rlecture: %lu %x",i,data);
i++;
set_adc_channel(2);
output_low(pin_a4);
While(i<60)
resultat=read_adc();
res2=(int)(resultat/4);
spi_write(res2); //On designe le data a envoyer
i++;
puts("valeur entree");
void son (void)
output_low(pin_a5);
output_low(pin_a4);
spi_write(0x03);
spi_write(0x00);
spi_write(0x00);
While(i<80)
data=spi_read(0);
i++;
output_high(pin_a5);
The main idea here is I want to sample the sound and and write to a EEPROM memory so I could reuse this sound later on and convert it with a CDA converter.
And also which CDA ( digital to analog convertor) is suitable for this task I have a MAX522 do you any idea if its good or not?
Neutone
PostPosted: Tue Feb 10, 2004 1:08 pm     Reply with quote
There has been some post on a 1bit audio solution that works very well.
Re: Sampling an 8 bit WAV file with a PIC
PostPosted: Thu Dec 08, 2005 7:20 am     Reply with quote
#include "16f877.h"
#include "stdlib.h"
#bit CKE = 0x94.6
#bit SMP = 0x94.7
#bit CKP = 0x14.4
#byte SSPSTAT=0x94
#byte SSPCON=0x14
#bit ADFM=0x9f.7
char choix;
int data=0,yx,res2;
void son (void);
void main (void)
set_tris_A(0xff);
set_tris_E(0x04);
ADFM=1;
i=0;
choix=getch();
if (choix=='1')
ecriture();
if (choix=='2')
lecture();
if (choix=='3')
conversion();
if (choix=='4')
son();
yx=getch();
getch();
output_low(pin_a4);
While(i<70)
i++;
printf("\n\r ok!");
void lecture (void)
output_low(pin_a4);
spi_write(0x03);
spi_write(0x00);
spi_write(0x00);
While(i<80)
data=spi_read(0);
i++;
set_adc_channel(2);
output_low(pin_a4);
While(i<60)
i++;
void son (void)
output_low(pin_a5);
output_low(pin_a4);
spi_write(0x03);
spi_write(0x00);
spi_write(0x00);
While(i<80)
data=spi_read(0);
i++;
