I2C, Master Reception, not making sense for pic18Fxx20
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Sun Dec 04, 2005 10:02 am     Reply with quote
In the 18F45X -> 18F45X0 "migration" document, it states one of the programming differences to pay attention to:
The MSSP module must be in an idle state before the RCEN bit is set, or the RCEN bit will be disregarded.
I don't understand how I would know that I am in the so-called "idle" state that the datasheet is referring to before I set RCEN. In fact, it seems contradictory because you have to SET the RCEN bit in order to receive.
The following function works just fine in the PIC18F458, but in the PIC18F4580, it gets stuck in the while-loop forever. I have a feeling I have encountered an issue in the migration document, but I still don't understand what's going on:
What do I have to do differently in the following i2c_read() function (besides implementing an i2c timeout watchdog):
unsigned int i2c_read(void)
    unsigned int return_value;
>>> You have to set RCEN to enable receive mode, right?? What do they mean that you have to be 'idle' before the RCEN bit is set??
    PIC_SSPCON2 |= PIC_SSPCON2_RCEN; // Enable receive mode.
    // Wait for the RCEN bit to clear
    while (PIC_SSPCON2 & PIC_SSPCON2_RCEN)
>>> PIC18F4580 i2c master gets stuck here, but PIC18F458 master works flawlessly.
    // Send NACK bit for ACKnowledge sequence.
    PIC_SSPCON2 |= PIC_SSPCON2_ACKDT;
    PIC_SSPCON2 &= ~PIC_SSPCON2_ACKEN; // Send ACK data now
    return_value = PIC_SSPBUF;
    return return_value;
PostPosted: Sun Dec 04, 2005 11:25 am     Reply with quote
The sequence I have used is:
start
send byte with the read flag set
_wait for the /ack to rise from slave_
Only once this is received, set the RCEN bit
Now clock your byte in, and /ACK this
stop.
Basically it seems to be critical that the slave has signalled it has acceptd the first byte, before RCEN is set.
valemike
PostPosted: Sun Dec 04, 2005 12:52 pm     Reply with quote
Thanks Ttelmah. I just realized that CCS's i2c_write() function checks to make sure that PIR1.SSPIF flag gets set before it continues on.
It makes sense now. I have always been loading SSPBUF and not waiting for the write to complete. And as you said, i can either wait for the ACK to rise from the slave, or i can wait for the SSPIF interrupt flag to get set.
This migration from '458 to '4580 isn't so trivial after all.
PostPosted: Sun Dec 04, 2005 3:10 pm     Reply with quote
It is this sort of little difference, that is often the worst....
