o_wan Guest
877 + SP232A |
Posted: Tue Nov 29, 2005 2:02 pm |
hi,
I was working w/ 877a with Sipex sp232a on serial communication, my code was simple (just putc('c')), I've checked that the pin conifg of sp232a is the same as max232, I've got it working but I was getting "garbage" instead of 'c' in either hyper teminal or serial port monitor, my clock is XT, 4 Mhz,
Here's my schematics,
sp(p1)-->0.1uf -->sp(p3)
sp(p2)-->0.1uf -->vcc
sp(p4)-->0.1uf -->sp(p5)
sp(p6)-->0.1uf -->gnd
sp(p11)--> PIC TX
sp(p12)--> PIC RX
sp(p13)--> DB9(p3)
sp(p14)--> DB9(p2) DB9(p5)-->gnd
Thanks, |
asmallri
Posted: Tue Nov 29, 2005 2:11 pm |
First check the software to ensure you have correctly setup the comms to match between the PIC and the PC. Have you set both ends up identically?
Check the #use rs232 and #use delay statements
#define XTAL_FREQ 4000000 //; OSC freq in Hz
#use delay(clock=XTAL_FREQ,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_B1,rcv=PIN_B4,bits=8,errors)
Hardware:
A common fault that will cause this problem is missing + or - voltage on the charge pump - usually caused by a poor solder joint on one of the capacitors. Measure the voltage between group and the capacitors and ensure that +9v and -9v are present. _________________ Regards, Andrew
