Bitwise exclusive OR
terciof
PostPosted: Thu Dec 01, 2005 7:22 pm     Reply with quote
Hi All.
I Have a var called MedicaoAtual, it will hold only 1 or 0. I declared this as int1, but...:
When I bitwise exclusive OR with it, the compiler generate a lot of code for just a exclusive OR. But if the var is declared as int only two instructions.
.................... MedicaoAtual ^= 1; <-- As int1
0788: MOVLW 00
0789: BTFSC 3E.1
078A: MOVLW 01
078B: XORLW 01
078C: MOVWF 78
078D: BTFSC 78.0
078E: GOTO 791
078F: BCF 3E.1
0790: GOTO 792
0791: BSF 3E.1
I need to verify this variable, if it's 1 PORTB.1 = 1 and PORTB.2 = 0, when it is 0, PORTB.1 = 0 and PORTB.2 = 1.
So, what is the best solution for this, I try a lot of possibilities like:
1:
   output_bit(PIN_B1, MedicaoAtual);
   output_bit(PIN_B2, input_state(PIN_B1)^1);
2:
   output_bit(PIN_B2, MedicaoAtual^1);
3:
    if(MedicaoAtual == 0)
        output_low(PIN_B1);
        output_high(PIN_B2);
        output_high(PIN_B1);
        output_low(PIN_B2);
All those methods works, but which one is the best one?
Thanks all.
Tercio
PostPosted: Thu Dec 01, 2005 7:31 pm     Reply with quote
0788: MOVLW 00
0789: BTFSC 3E.1
078A: MOVLW 01
078B: XORLW 01
078C: MOVWF 78
078D: BTFSC 78.0
078E: GOTO 791
078F: BCF 3E.1
0790: GOTO 792
0791: BSF 3E.1
You want to invert an int1 variable ? Try this method:
int1 MedicaoAtual;
MedicaoAtual = !MedicaoAtual;
Here is the ASM listing. It does an XOR with 1 on the specific bit.
0000                00504 ....
0000                00505 .... MedicaoAtual = !MedicaoAtual;
0091 3001       00506 MOVLW  01
0092 06AB       00507 XORWF  2B,F
