LCD Control Wires Split Across 2 PORTS
kg6vkg
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Sat Nov 26, 2005 11:56 pm     Reply with quote
Greetings. I bought the PCWH software last week and am trying to get familiar with it. I am pretty familiar with the pic assembler, and am now trying to branch into the C language.
I am using:
Microcontroller: PIC 18LF4520
LCD: 4x16 character Hitachi HD44780 LCD.
and I have #included the lcd.c file from the PICC C library.
In the new project wizard I selected to have the LCD driver installed. Now I am trying to see how I am going to adapt your LCD library to my application. I see in the LCD program it relies on me overlaying the “struct lcd_pin_map” over a port. I am not sure how to make this work for me.
struct lcd_pin_map { // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
In my application:
My LCD Pin setup:
RE0: RS
RA5: R/W
RA4: Enable
RA0: LCD-DB4
RA1: LCD-DB5
RA2: LCD-DB6
RA3: LCD-DB7
My problem lies in the RE0 pin. Is this going to be a major problem that I am split across two ports? I don’t have an entire port to dedicate to the LCD. PORTA is the only contiguous port I have available. PORTA starts at 0xF80, and PORTE starts at 0xF84.
What is my best solution?
If anyone has any ideas let me know. I would appreciate any help any one has.
Best Regards,
Mark McKinley
PostPosted: Sun Nov 27, 2005 12:07 am     Reply with quote
My problem lies in the RE0 pin. Is this going to be a major problem that I am split across two ports.
Look in the CCS Code Library forum. There are drivers posted there
that allow you to spread the LCD signals over two or more ports.
http://www.ccsinfo.com/forum/viewtopic.php?t=20182
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
kg6vkg
Thanks for the code
PostPosted: Thu Dec 01, 2005 9:45 pm     Reply with quote
That code worked perfect, thanks for the links. My LCD is working great now.
-Mark
