according to data sheet PIC16F876/7A has 386 bytes of RAM. In the header of the lst-file you can see that 146 bytes are about 83%. when i want to add an int8 array of 64 the message would be: "Not enough RAM for all variables". there shoud be sufficient RAM. what's wrong? can you help me?
regards
Peter
CCS PCM C Compiler, Version 3.235, 26231 23-Nov-05 23:15
Filename: logger.LST
ROM used: 3101 words (38%)
Largest free fragment is 2048
RAM used: 119 (68%) at main() level
146 (83%) worst case
Stack: 4 worst case (3 in main + 1 for interrupts)
