Mark Haines Guest
16F877 refusing to do anything |
Posted: Sun Nov 18, 2001 3:46 am |
I'm trying to program a 16F877 using the Warp13 programmer and can't get any response out of the chip. I'm using the CCS compiler, and even the simplest program refuses to run. For example:
#include <16f877.h>
#use delay (clock=20000000)
main()
output_high(PIN_A2);
output_low(PIN_A2);
This compiles and programs just fine, but I'm not seeing any oscillation on the pin. As far as I can tell, my code's not even getting run.
Admittedly, a lot of pins on the PIC are floating because they're not used right now... don't know if that could be part of the problem.
I've also tried this on 3 or 4 MCUs, so I don't have a bad PIC.
Any help anyone could offer would make my day. Thanks!
~Mark
___________________________
Original Post ID: 1190 |
Felix Althaus
Joined: 09 Sep 2003 Posts: 67 Location: Winterthur, Switzerland
Re: 16F877 refusing to do anything |
Posted: Sun Nov 18, 2001 4:47 am |
Hi
Did you set the fuse options right in the programmer dialogue?
(try "picchips pic16f877" on the command prompt for available fuses or see the data sheet)
mfg
Felix
Original Post ID: 1192 |
Frank Guest
Posted: Sun Nov 18, 2001 4:59 am |
The warp-13 defaults to “Force-ISP”. If you are not using the ISP you must uncheck it. See options in Warp-13
-Frank
:=I'm trying to program a 16F877 using the Warp13 programmer and can't get any response out of the chip. I'm using the CCS compiler, and even the simplest program refuses to run. For example:
:=#include <16f877.h>
:=#use delay (clock=20000000)
:=main()
:= while(TRUE)
:= output_high(PIN_A2);
:= delay_ms(500);
:= output_low(PIN_A2);
:= delay_ms(500);
:=This compiles and programs just fine, but I'm not seeing any oscillation on the pin. As far as I can tell, my code's not even getting run.
:=Admittedly, a lot of pins on the PIC are floating because they're not used right now... don't know if that could be part of the problem.
:=I've also tried this on 3 or 4 MCUs, so I don't have a bad PIC.
:=Any help anyone could offer would make my day. Thanks!
:=~Mark
Original Post ID: 1193 |
pha555 Guest
Posted: Sun Nov 18, 2001 8:08 am |
Note that PORTA defaults to the A/D converter.
You might try your program on PORTB.
Peter H Anderson, <a href="http://www.phanderson.com" TARGET="_blank">http://www.phanderson.com</a>
:=main()
:= while(TRUE)
:= delay_ms(500);
:= delay_ms(500);
:=~Mark
Original Post ID: 1194 |
Dave Y. Guest
Posted: Sun Nov 18, 2001 8:50 am |
CCS defaults to A/D on port A. You have to turn this off if you are going to use the pins for digital input/output.
You have to add the line:
setup_adc(ADC_OFF);
This should fix it...
Dave
:=main()
:= while(TRUE)
:= delay_ms(500);
:= delay_ms(500);
:=~Mark
Original Post ID: 1196 |
Mark Haines Guest
Posted: Sun Nov 18, 2001 2:46 pm |
:=You have to add the line:
:= setup_adc(ADC_OFF);
I know we tried this at least once; we've also tried using PORTC instead, and, I believe PORTD.
We've tried a variety of sample programs and have gotten absolutely no indication that the PIC is doing anything whatsoever. All the pins are floating low except the oscillator output.
Original Post ID: 1202 |
Mark Haines Guest
Posted: Sun Nov 18, 2001 2:48 pm |
:=The warp-13 defaults to “Force-ISP”. If you are not using the ISP you must uncheck it. See options in Warp-13
What effect would this have exactly? The MCU programs and verifies just fine each time... It just doesn't run, apparently. I haven't yet had a chance to test turning off "Force-ISP", though... I'll keep you posted if that helps.
Original Post ID: 1203 |
Michael Langford Guest
Posted: Sun Nov 18, 2001 6:29 pm |
I am Mark's partner(the gentleman who originated this thread). I tried turning off that option this afternoon. Nothing changed. I actually rewrote the program into assembler, and it still doesn't do anything once its programed.
The assembler program sets all the ports to outputs, then sets the a/d to all digital. It uses the HS oscillator option, and no watchdog timer or brownout detect. Then it sets portc,2 to 1. This still doesn't do anything.
Could someone take some code that they have for the 16f877 that does work and uses the internal oscillator and post/mail the initalization section?
Or does anyone know of a simple program like that on the web that just sanity checks that you have the fuses set correctly and your programmer is actually programming?
--Michael
:=-Frank
:=:=I'm trying to program a 16F877 using the Warp13 programmer and can't get any response out of the chip. I'm using the CCS compiler, and even the simplest program refuses to run. For example:
:=:=#include <16f877.h>
:=:=#use delay (clock=20000000)
:=:=main()
:=:= while(TRUE)
:=:= output_high(PIN_A2);
:=:= delay_ms(500);
:=:= output_low(PIN_A2);
:=:= delay_ms(500);
:=:=This compiles and programs just fine, but I'm not seeing any oscillation on the pin. As far as I can tell, my code's not even getting run.
:=:=Admittedly, a lot of pins on the PIC are floating because they're not used right now... don't know if that could be part of the problem.
:=:=I've also tried this on 3 or 4 MCUs, so I don't have a bad PIC.
:=:=Any help anyone could offer would make my day. Thanks!
:=:=~Mark
Original Post ID: 1208 |
Dave Y. Guest
Posted: Sun Nov 18, 2001 6:35 pm |
I tried this program exactly as you posted it and it works for me using my Warp13 programmer. I also tried it with my ICD and it also worked.. You apparently have hardware issues on that end.
Dave
The follwing is the list file that I generated.
CCS PCM C Compiler, Version 3.058, 6945
Filename: D:\PIC\MPLAB\PROJECT\MISC\TST877.LST
ROM used: 54 (1\%)
Largest free fragment is 2048
RAM used: 6 (3\%) at main() level
7 (4\%) worst case
Stack: 1 locations
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 017
0003: NOP
.................... #include <16f877.h>
.................... //////// Standard Header file for the PIC16F877 device ////////////////
.................... #device PIC16F877
.................... #list
.................... #use delay (clock=20000000)
0004: MOVLW 22
0005: MOVWF 04
0006: MOVF 00,W
0007: BTFSC 03.2
0008: GOTO 016
0009: MOVLW 06
000A: MOVWF 78
000B: CLRF 77
000C: DECFSZ 77,F
000D: GOTO 00C
000E: DECFSZ 78,F
000F: GOTO 00B
0010: MOVLW 7B
0011: MOVWF 77
0012: DECFSZ 77,F
0013: GOTO 012
0014: DECFSZ 00,F
0015: GOTO 009
0016: RETLW 00
.................... main()
0017: CLRF 04
0018: MOVLW 1F
0019: ANDWF 03,F
001A: MOVLW 9F
001B: MOVWF 04
001C: MOVLW 07
001D: MOVWF 00
.................... while(TRUE)
.................... output_high(PIN_A2);
001E: BSF 03.5
001F: BCF 05.2
0020: BCF 03.5
0021: BSF 05.2
.................... delay_ms(500);
0022: MOVLW 02
0023: MOVWF 21
0024: MOVLW FA
0025: MOVWF 22
0026: CALL 004
0027: DECFSZ 21,F
0028: GOTO 024
.................... output_low(PIN_A2);
0029: BSF 03.5
002A: BCF 05.2
002B: BCF 03.5
002C: BCF 05.2
002D: MOVLW 02
002E: MOVWF 21
002F: MOVLW FA
0030: MOVWF 22
0031: CALL 004
0032: DECFSZ 21,F
0033: GOTO 02F
0034: GOTO 01E
0035: SLEEP
Original Post ID: 1209 |
Richard Katezansky Guest
Posted: Sun Nov 18, 2001 7:00 pm |
:=main()
:= while(TRUE)
:= delay_ms(500);
:= delay_ms(500);
Apart from PortA defaulting to analog on a hard reset all ports default to inputs. You must set the DDR or TRIS register for the port in question to output by clearing the appropriate bits.
:=~Mark
Original Post ID: 1210 |
Mark Haines Guest
Fixed! |
Posted: Sun Nov 18, 2001 11:47 pm |
Aha! Turned out we were having oscillator problems... Once we got the clock oscillator worked out, everything started working for us. Thanks for all your help, everybody!
~Mark
Original Post ID: 1215 |
Dave Yeatman Guest
Re: Fixed! |
Posted: Mon Nov 19, 2001 3:01 pm |
Mark,
I had problems with 20 mhz oscillators and parasitic capacitance when the leads were too long or placement wasn't just right. I bought a bunch of half size 12,16, 18.432 and 20MHZ cans and now I no longer have to worry about that. I can pretty much put the osc where I want. I also get a much more stable and accurate oscillator as a side benefit.
Dave
:=Aha! Turned out we were having oscillator problems... Once we got the clock oscillator worked out, everything started working for us. Thanks for all your help, everybody!
:=~Mark
Original Post ID: 1237 |
