string Hex into int |
Posted: Wed Nov 16, 2005 6:08 am |
I'm trying to translate the following ASCII string: "RD 2B0 A3 58"
into: RD, 0x2b0, 0xA3, 0x58
What is the simples why to do it ? |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Posted: Wed Nov 16, 2005 7:39 am |
I would write something like this: Code: | #define NUMBER_OF_VALUES 4
int i, k, value;
int16 values[NUMBER_OF_VALUES] = {0,0,0,0};
k = 0;
for (i = 0; i < length(ASCIIstring); i++)
if (i == ' ')
k++;
value = 0;
if (k == NUMBER_OF_VALUES)
i = 255;//to avoid array-overflow
value = ASCIIstring[i] - '0';
if (value > 9)
value = (value + '0') - 'A';
values[k] = (values[k] * 16) + value;
this code might contain syntax errors and so you should check it first.
Off course, there are more ways to do it, and this is probably not the best... |
Posted: Thu Nov 17, 2005 2:01 am |
Thanks,
This example was waht I'm looking for .. |
