Time to Write to Internal Eeprom & Flash?
KenMacfarlane
PostPosted: Mon Nov 21, 2005 5:11 am     Reply with quote
I want to buffer 20-30 bytes of data arriving every few seconds, to any spare internal eeprom or flash program memory that I've got left Idea , on a 10 MHz Modtronics SB65 (PIC18f6621), in case I loose the serial link to a PC host for a few minutes.
Anybody know how long it takes to read or write using these funcs? Question
write_eeprom & read_eeprom
write_program_eeprom & read_program_eeprom
write_program_memory & read_program_memory
Neither the CCS help or manual give any idea, but I presume that there is a "write every few hundred microseconds" until it reads back correct going on inside the write routines, and that this might take a few millisecs per byte????
asmallri
PostPosted: Mon Nov 21, 2005 6:27 am     Reply with quote
The CCcode overhead is negligible. The time is dependant on the write characteristics of the device and can be found in the data sheet for the processor. For example, a 18F1320 has an 18ms page write to Flash Program Memory time. The CCS executes the write and waits until it is complete before returning.
Regards, Andrew
