jack// ani Guest
RF module code |
Posted: Sat Nov 12, 2005 1:05 am |
Hi all,
I need codes for data transmission....between PIC uC, connected to 433MHz RF module. Basically I want to control a motor...the Tx module will send the commands and RX will act accordingly. Please help me......
Thanks a lot |
specialk
Posted: Sat Nov 12, 2005 5:11 pm |
Look up "manchester encoding" to find information on wireless data transmissions.
-special [k] |
jack// ani Guest
Posted: Mon Nov 14, 2005 11:13 am |
Thanks......I cannot get any well working codes. I'll appreciate a lot if anyone could please share his codes here.....please.
thanks a lot |
newguy
jack// ani Guest
Posted: Tue Nov 15, 2005 9:44 am |
Hi newguy,
Thanks for that. I understood whole of the codes....except two of these lines....please explain its purpose
valid_data_count = 0xff; // get ready to count the number of data bytes - we know we have to expect 5 (Rocks)
and
if (got_id && ++valid_data_count == 5)
thanks
Source code for the reciever is.....
#include <18F8621.h>
#device *=16 ADC=8
#define Fosc 40000000
#define WireTX PIN_C6
#define WireRX PIN_C7
#define ConsTX PIN_G1
#define ConsRX PIN_G2
#use delay(clock = Fosc,RESTART_WDT)
#fuses EC_IO, BROWNOUT, BORV20, PUT, STVREN, NOLVP
#use rs232(baud=9600, xmit=WireTX, rcv=WireRX, ERRORS, STREAM=Wireless)
#use rs232(baud=9600, xmit=ConsTX, rcv=ConsRX, ERRORS, STREAM=Console) //Setup RS232
#define RX_BUFFER_SIZE 80
#define TX_BUFFER_SIZE 80
int8 rx_wr_index = 0, tx_rd_index = 0, tx_wr_index = 0, tx_counter = 0, received = 0;
int8 lock_state = 0, rxd, i, valid_data_count;
unsigned int8 rx_buffer[RX_BUFFER_SIZE + 1], tx_buffer[TX_BUFFER_SIZE + 1];
int1 data_avail = FALSE, got_id = FALSE;
#int_RDA
void RDA_isr(void) {
rx_buffer[rx_wr_index] = getc();
rxd = rx_buffer[rx_wr_index]; // this just makes it easier typing-wise later on
rx_wr_index++;
if (rx_wr_index > RX_BUFFER_SIZE) {
rx_wr_index = 0;
// now look for unique ID: "Dave "
if (rxd == 'D' && lock_state == 0) {
lock_state++;
else if (rxd == 'a' && lock_state == 1) {
lock_state++;
else if (rxd == 'v' && lock_state == 2) {
lock_state++;
else if (rxd == 'e' && lock_state == 3) {
lock_state++;
else if (rxd == ' ' && lock_state == 4) { // got the entire string "Dave ", in that order
lock_state = 0; // reset our "combination lock"
got_id = TRUE;
// also going to reset the buffer write index back to 0, so that I know where my valid data will be
rx_wr_index = 0;
else { // we didn't receive "Dave ", so reset the lock back to the beginning
lock_state = 0;
if (got_id && ++valid_data_count == 5) {
data_avail = TRUE;
got_id = FALSE;
#int_TBE
void TBE_isr(void) {
if (tx_counter != 0) {
putc(tx_buffer[tx_rd_index]);
if (++tx_rd_index > TX_BUFFER_SIZE) {
tx_rd_index = 0;
tx_counter--;
if (tx_counter == 0) {
disable_interrupts(INT_TBE);
void bputc(int c) {
int restart = 0;
while (tx_counter > (TX_BUFFER_SIZE - 1));
restart = 1;
tx_buffer[tx_wr_index++] = c;
if (tx_wr_index > TX_BUFFER_SIZE) {
tx_wr_index = 0;
tx_counter++;
if (restart == 1) {
enable_interrupts(INT_TBE);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL|RTCC_OFF|RTCC_8_bit);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_RDA);
//enable_interrupts(INT_TBE);
enable_interrupts(global);
set_tris_e(0);
fprintf(Console,"working");
while (TRUE) {
restart_wdt();
if (data_avail) {
data_avail = FALSE;
fprintf(Console,"\r\n\r\nData is now available\r\nData: ");
for (i = 0; i < 5; i++) {
fprintf(Console,"%c",rx_buffer[i]);
newguy
Posted: Tue Nov 15, 2005 10:08 am |
jack// ani wrote: | Hi newguy,
and
thanks
valid_data_count is what its name implies, just a count of the valid characters. In this simple example, the valid data is "Rocks" (minus the quotes). I initially set valid_data_count to 0xff, which is 255 because valid_data_count is an 8 bit integer.
Now the next line, if (got_id && ++valid_data_count == 5) executes. got_id is now true, and "++valid_data_count" means first increment valid_data_count (255 wraps to 0), and then check to see if the new value of valid_data_count is equal to 5. If both of these conditions are true, we've received the 5 bytes of the message we're expecting.
Now that I think of it, it is quite confusing. Would it help if I told you that you can change valid_data_count to be initialized to 0 (instead of 255), and change the "== 5" to "== 6". Might be a bit easier to follow.
Hope this helps. |
jack// ani Guest
Posted: Tue Nov 15, 2005 2:51 pm |
Thanks a lot.......you are very helpful. I really appreciate it a lot.
thanks again |
