kbhit
Alvin
kbhit
PostPosted: Mon Nov 14, 2005 3:09 pm     Reply with quote
Hi can someone please post the source code for kbhit(), which registers or bits does it check in PIC18F2480? Any help would be greatly appreciated.
PostPosted: Mon Nov 14, 2005 3:20 pm     Reply with quote
I can tell you how to do this:
Compile a small test program and look at the .LST file that is generated
after a successful compilation. It's in your project folder. It will show
the ASM code generated by the compiler for the kbhit() function.
Also, if you want the listing to show register names (instead of the
hex address of the registers), then in MPLAB, go to Project/Build Options
and in the Compiler tab, in the List File Options, select Symbolic Format.
