PIC18F452 how to apply code protection using programmer opt?
PostPosted: Mon Nov 14, 2005 4:15 am     Reply with quote
Hello All,
I have a problem regarding applying Code protection of PIC18F452. I have written a code for PIC18F452 and its program memory is almost fill i.e code 32070 editor shows.
According to my knowledge correct me if i am worng that CP0-CP1-CP2,CP3 bits of PIC18F452 register should be set to all zero to protect PIC18F452's code from read. But when i do this my PIC dont works. Although i have checked this thing when my code is not too much as 32070 (i.e programm memory nearly filled). then it works ok.
Where i am wrong..
regrads
PostPosted: Mon Nov 14, 2005 5:53 pm     Reply with quote
If you have the CCS compiler, just put PROTECT in the #fuses statement
as shown below. This will set all the CPx bits = 0 and enable code
protection.
#include <18F452.h>
#fuses XT,NOWDT,PROTECT,PUT,BROWNOUT,NOLVP
I suspect that you may not have the CCS compiler, and you may
be setting the CPx bits by other means. You are probably trashing the
config bits in some other config register and this causes your program
to lock-up.
