DS1302
ccmcca
DS1302
PostPosted: Thu Nov 10, 2005 2:29 pm     Reply with quote
What is NVR??
In this driver...
rtc_write_nvr(address,data) Write to NVR
data = rtc_read_nvr(address) Read from NVR
PostPosted: Thu Nov 10, 2005 2:39 pm     Reply with quote
What is NVR??
Non Volatile RAM
Many clock chips have some spare memory that you can use for storing data. This data will not be lost on power off as it is backed up by the same battery the clock is using. Usefull for storing passwords, etc.
PostPosted: Thu Nov 10, 2005 2:54 pm     Reply with quote
Ok! THANKS
You Know wich pin i have to use to connect a battery?
PostPosted: Thu Nov 10, 2005 3:11 pm     Reply with quote
If I remember correctly there are several options, depending on using a standard battery or a rechargeable battery / Super Capacitor. Please study the datasheet from www.maxim-ic.com.
