Question About Unions
csanders
PostPosted: Mon Nov 07, 2005 11:47 pm     Reply with quote
Hello All
I have an 8 bit variable that I would like to be able to modify either by writing a value directly to it or by modifiying individual bits in the variable. From what I understand about c is that this is what a union is used for. Here is my code--
union ier {
   int1 rhr_int;     //RHR Interrupt Enable 0=Disable, 1=Enable
   int1 thr_int;     //THR Interrupt Enable 0=Disable, 1=Enable
   int1 rxline;      //Rx Line Status Interrupt 0=Disable, 1=Enable
   int1 msr_int;   //Modem Status Register Interrupt 0=Disable, 1=Enable
   int1 sleep;      //Sleep Mode 0=Disable, 1=Enable
   int1 xoff_int;   //XOFF Interrupt 0=Disable, 1=Enable
   int1 rts_int;     //RTS Interrupt 0=Disable, 1=Enable
   int1 cts_int;    //CTS Interrupt 0=Disable, 1=Enable
   int8  value;    //Raw Register Value
}ier_set;
When I set ier_set.sleep = 1, I expect to see ier_set.value = 0x10, however what I actually get is all of the individual bits = 1 and the ier_set.value = 1. Can anyone see what I've done wrong or suggest an alternate method of performing this task?
Thanks a bunch
PostPosted: Tue Nov 08, 2005 4:36 am     Reply with quote
The key here, is that you are declaring eight _seperate_ int1 variables, which therefore are each mapped in the union, to the same space. Changing any one will change all the others (which is what a union is about!).
Effectively you need to declare a _single_ variable, containing 8 'bits', to get the behaviour you require.
There are a number of ways of doing this. The first (in CCS), is to declare a structure containing the eight bit fields, as (say)
struct bits {
and then declare the union to contain one of these structures, and the int8, as:
union ier {
   struct bits b;
   int8 value;
}ier_set;
Then you can access the bits as ier_set.b.rhr_int etc..
Though this should work, it is probably better to use the 'bit field' declaration, rather than int1, since this ensures that the bits genuinely are aligned into a single integer. So:
struct bits {
   int8 rhr_int : 1;     //RHR Interrupt Enable 0=Disable, 1=Enable
   int8 thr_int : 1;     //THR Interrupt Enable 0=Disable, 1=Enable
   int8 rxline : 1;      //Rx Line Status Interrupt 0=Disable, 1=Enable
   int8 msr_int : 1;   //Modem Status Register Interrupt 0=Disable, 1=Enable
   int8 sleep : 1;      //Sleep Mode 0=Disable, 1=Enable
   int8 xoff_int : 1;   //XOFF Interrupt 0=Disable, 1=Enable
   int8 rts_int : 1;     //RTS Interrupt 0=Disable, 1=Enable
   int8 cts_int : 1;    //CTS Interrupt 0=Disable, 1=Enable
This declares the 'bits', to be single bit fields inside an int8 variable, which can then be mapped with the union to the same space as another normal 'int8'.
This approach is probably the most 'portable' solution.
You can though also do the same thing, by not using a union, and just using the #bit declaration in CCS. So if you declare an int8, called 'ier_set', you can declare bits as:
#bit rhr_int=ier_set.1
This is 'specific' to CCS, but does make the in-use declarations very simple.
There are a number of other similar methods of doing this, and if you look at how the port declarations are done on some of the posted code, for things like LCD I/O, you will see a number of the other solutions.
csanders
PostPosted: Tue Nov 08, 2005 11:41 pm     Reply with quote
Thank you
That is exactly what I was trying to do. Your help is greatly appreciated.
