Adam P. Guest
RF modules for PIC 16F family? |
Posted: Mon May 09, 2005 2:40 pm |
I would like to know which RF modules fit best for mid-range PIC based projects and if there´s anyone who has tested them with this compiler.
I´ve seen some modules in sparkfun.com, could anyone give me an advice of wich one is best for medium velocity transmision?
I am looking for RF modules operating at 4800 bps in distances below 100 meters and cheap enough.
Thank you |
libor
Posted: Mon May 09, 2005 4:28 pm |
I have used modules from Xemics successfully with the 18F range PICs, I have managed to make the PICs built-in I2C to communicate with the Xemics modules taking the data flow, and used some other ports to control the RF module's operation.
Here are the Xemics DP 1203 modules |
Adam P. Guest
Posted: Wed May 11, 2005 5:58 am |
Thanks for your reply, but what I´m really looking for is a RF module with built in anthena, so I won´t have troble making my own anthena.
Thank you |
chi_co Guest
CHI_COd |
Posted: Sun Nov 06, 2005 2:19 am |
Adam P. wrote: | Thanks for your reply, but what I´m really looking for is a RF module with built in anthena, so I won´t have troble making my own anthena.
Thank you |  |
kender
Re: RF modules for PIC 16F family? |
Posted: Sun Nov 06, 2005 2:45 am |
Adam P. wrote: | I am looking for RF modules operating at 4800 bps in distances below 100 meters and cheap enough. |
I have used MaxStream XCite, which was $34. http://www.maxstream.net/products/xcite/module/9xcite.php
You might also consider 100mW Bluetooth. |
jecottrell
Posted: Sun Nov 06, 2005 7:29 am |
I'll second Kender's recommendation.
I have used MaxStream radios with ease. I've just started with their new XBee radios (use caution their quoted ranges may be a little optomistic.) They have a variety of options for the range you need.
Essentially the radio is a simple serial link without the hassle of a RS232 level converter.
Good luck,
John |
