pic 16f877 & hard disk
enzullo
PostPosted: Thu Mar 06, 2003 8:45 am     Reply with quote
is possible to use pic 16f877 to read data from RS232 ( or usb using ftdi chip) and store them into an hard disk.
any link ?!?!?
any idea ?!?!?
any code ?!?!?
tnx enzullo
___________________________
Original Post ID: 12424
Mark
Re: pic 16f877 & hard disk
PostPosted: Thu Mar 06, 2003 12:02 pm     Reply with quote
Yes it is possible. You will probably need external RAM to store a sectors worth of data before dumping it to the HDD. This could better be accomplished with an 18F452 since it has about 1.5K of RAM. Search the net for info on MP3 players. Many of the players due this sort of thing.
:=is possible to use pic 16f877 to read data from RS232 ( or usb using ftdi chip) and store them into an hard disk.
:=any link ?!?!?
:=any idea ?!?!?
:=any code ?!?!?
:=tnx enzullo
Original Post ID: 12432
enzullo
PostPosted: Thu Mar 06, 2003 12:33 pm     Reply with quote
<font face="Courier New" size=-1>tnx
you know same link to view this project ?!?!
:=Yes it is possible. You will probably need external RAM to store a sectors worth of data before dumping it to the HDD. This could better be accomplished with an 18F452 since it has about 1.5K of RAM. Search the net for info on MP3 players. Many of the players due this sort of thing.
:=:=is possible to use pic 16f877 to read data from RS232 ( or usb using ftdi chip) and store them into an hard disk.
:=:=any link ?!?!?
:=:=any idea ?!?!?
:=:=any code ?!?!?
:=:=tnx enzullo</font>
Original Post ID: 12436
ignacio seron
PostPosted: Thu Mar 06, 2003 1:20 pm     Reply with quote
I recomend to you use a compact flash, you can use the 8 bit data bus.
Now i'm developing a very same project, we can share info and knowledge.
IGnacio.
:=you know same link to view this project ?!?!
:=:=Yes it is possible. You will probably need external RAM to store a sectors worth of data before dumping it to the HDD. This could better be accomplished with an 18F452 since it has about 1.5K of RAM. Search the net for info on MP3 players. Many of the players due this sort of thing.
:=:=:=is possible to use pic 16f877 to read data from RS232 ( or usb using ftdi chip) and store them into an hard disk.
:=:=:=any link ?!?!?
:=:=:=any idea ?!?!?
:=:=:=any code ?!?!?
:=:=:=tnx enzullo</font>
Original Post ID: 12437
