PIC TO PIC COMUNICATION
ccmcca
PostPosted: Sat Oct 29, 2005 1:58 pm     Reply with quote
How can i send a variable from one pic to another?
Is rs232 or I2C the better method?
I need an example.
Thanks!!.-
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Sat Oct 29, 2005 3:08 pm     Reply with quote
It depends on the length of your transmission line (in meters), on your desired data rate and directionality of your communication, your constraints such as power consumprion, board size, EMI (including galvanic isolation) and - finally - cost. Tell us more about your application.
Here are a few typical cases (in no particular order):
* A "master controller" and secondary controller(s) on the same board (or at least in the same box without a lot of EMI). I would recommend I2C. Most PICs have a hardware I2C protocol engine, plus I2C doesn't require bus transceivers. There is code for I2C master and I2C slave in this forum.
* Pier-to pier network. Take a look at Controller Area Network (CAN). Again, there is code for CAN comunication in the forum and in the examples. However, CAN requires bus transcievers.
rwyoung
PostPosted: Sat Oct 29, 2005 3:14 pm     Reply with quote
You tie your boat to a PIER and you talk to your PEER... Wink
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
PostPosted: Sat Oct 29, 2005 4:16 pm     Reply with quote
I have the two chips in the same board.
this is the code
receiver
#include "mainbalanza.h"
#int_RDA
RDA_isr()
printf(LCD_PUTC,"DEBUG";
ini();
sender
#include "USvar16f627.h"
while(true)
printf("%S\n\r","16f627";
dyeatman
PostPosted: Sun Oct 30, 2005 7:49 am     Reply with quote
Read the CCS FAQ. It has an example and tells you what CCS example code you can use to implement the example.
PostPosted: Sun Oct 30, 2005 7:58 am     Reply with quote
Also look at the threads here, about interrupts, and serial interrupts in particular.
Your receive interrupt _must_ retrieve the character, or it'll sit in a permanent loop, since it'll keep retriggering waiting for the character to be accepted. You are sending 8 characters, and never retrieving any...
